12743 Diskussionen
Disable FPU on Arria10 SoC FPGA
Geehrter Beitragender II
2.288Aufrufe
Hi Support,
We need to disable FPU on Arria 10 SoC FPGA.
Please let us know the procedure how to disable FPU.
Karthik.
6 Antworten
1.002Aufrufe
Karthik,
all you need to do is to clear bit# 30 of the FPEXC register:
fmrx r0, FPEXC
bic r0, r0,# 0x40000000
fmxr FPEXC, r0
1.002Aufrufe
--- Quote Start ---
Karthik,
fmrx r0, FPEXC
fmxr FPEXC, r0
--- Quote End ---
I ran the above assembly code(assembler) and generated binary from object file, when i try to execute binary it shows segmentation fault.
please let me know how to check FPU is disabled/not after running the assembly code.
1.002Aufrufe
If it traps accessing the FPEXC register, it is likely because the processor is running in user mode.
FPEXC can only be accessed in privilege mode.
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0068b/bcfhhbdd.html
1.002Aufrufe
--- Quote Start ---
--- Quote End ---
Thanks ericv. I will try it in privilege mode.
1.002Aufrufe
I'm not sure about that one:
You could also hit another roadblock if the library was built for EABI hard-float.
EABI hard-float means float/double arguments for functions are typically passed in the FPU registers instead of the R0->R12 basic set.
As the FPU is disabled, if my understanding is correct, and if your library is hard-float, you will get traps.
1.002Aufrufe
This will be work:
fmrx r0, FPEXC
fmxr FPEXC, r0
Antworten
