EPCS16 and problems
Hi guys.
I met a problem.As i understand, I am not first person,which has same problems.
Lets go.
When i try to program flash memory(Altera EPSC16N) by HW and for this purpose i have .jic file, everything is going perfectly. Then (after board restart) if i want to check some Nios2 code by Debug - again everything is perfect. But when i try to program flash(EPCS) by Nios image - here problems are starting.I am trying to program by nios2-flash-programmer-gui.
In my application, reset-vector points to epcs_flash_controller_0.
When i program flash, i receive following output:
EPCS signature is 0xFF
EPCS device doesn't support RDID command
No EPCS layout data - looking for section[EPCS-FF]
Unable to use EPCS device
Leaving target processor paused
Error Code: 8 for command ...
I added nios2-flash-override.txt file and i receive same result.
I even changed epcs component.
It looks, like programmer cannot read correct sugnature.
I also have other board with EPCS4N flash memory.In this memory everything is perfect.
Plz,help guys.
It is urgent.
Thank you, Slava.
I want to continue on this old thread but adding new conditions for the same error.
I'm getting exactly the same error:
But a singularity is that I'm only getting it when programming a certain system. So it should be an error in the description (Qsys). The only difference between this system is that I added SDRAM, but it works when running on Nios II HW so I'm guessing SDRAM is not the problem, or is it?.
*Should I use a tri-state?
I am having the same issue with an EPCS64N. I have two boards running identical .sof loads - one works and returns this from nios2-flash-programmer:
Looking for EPCS registers at address 0x30000400 (with 32bit alignment)
Initial values: 00000000 00000000 00000260 00000000 00000000 00000001
Valid registers found
epcs signature is 0x16
EPCS identifier is 0x202017
Using EPCS size information from section [EPCS-202017]
Device size is 8MByte (64Mbit)
Erase regions are:
offset 0: 128 x 64K
EPCS status is 0x00
The other fails and returns this:
epcs signature is 0xff
No EPCS layout data - looking for section [EPCS-FF]
Does anybody know why an identical (in theory) circuit and device would return a signature of 0xFF? I have replaced the EPCS64N - same result. I checked the DCLK, DATA, nCS, and ASDI signals with a scope and all look good and similar between boards.
Are there bad devices floating around? (These were purchased from DigiKey - an authorized Altera distributor.)
It appears that my problem is an open circuit between the EPCS and the FPGA on DATA0. I will update this post if that is found not to be the fault.
