EPCS4: Compilation problem
hello Good people
I'm trying to add a EPCS4 flash momery to my desing. I'm not able to compile it:
When compiling I get the following error msg:
Error: Can't place the following nodes
Error: Can't place node "NiosII:inst|epcs_controller:the_epcs_controller|tornado_epcs_controller_ato
m:the_tornado_epcs_controller_atom|internal_data0out" of type ASMI Block
Error: Can't fit design in device
Error: Quartus II Fitter was unsuccessful. 3 errors, 38 warnings
Error: Processing ended: Sat Sep 30 14:40:01 2006
Error: Elapsed time: 00:00:11
Error: Quartus II Full Compilation was unsuccessful. 3 errors.
I'm relatively new to Quartus II and SOPC builder and I can't figure out where the problem lies.
My board is EP1C12 cyclone.
My desing is very simple. It only contains the following components:
- Nios II/e CPU with on-chip memory
- One timer
- EPCS flash controller
- Active Serial Memory Interface
- 2 input pins : sys_clk and sys-rest_n assigned pins 29 and 62 respectively.
I don't know if I missed to add some important device, pin or interface to make it work.
I would be greatful if there is some1 out there willing to help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif .
Thanks in advanced.
Hi Pegazaus
I&#39;m not sure but for me it seems that active serial memory interface contradicts with epcs controller. Why do you need active serial interface? Do you know that you can read & write directly from epcs device through epcs controller? For more information see Nios II Software Developer&#8217;s Handbook alt_flash_open_dev().
Good luck!
Thx. You are right
