12748 Discussions
LOading and Running software on NiosII Processor
I have a question,
How can I load and run a program I wrote outside of NIOSII IDE?
I have a large packag with it's make system. I don't want to import it into NiOSII IDE (ECLIPSE) since there are configuration file related.
Can any one help? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
If you all Makefile required files.. You can load run through NIOS SDK Shell.
You can refer to Nios embedded processor software development reference manual which is talking more on makefiles. And you can follow one tutorial tt_nios_sw.pdf.. which is covering NIOS SDK Shell commands and process.
Some correction to 1st line.
If you have all Makefile required files.. You can load, run through NIOS SDK Shell.
