hello Good people
I'm trying to add a EPCS4 flash momery to my desing. I'm not able to compile it: When compiling I get the following error msg: Error: Can't place the following nodes Error: Can't place node "NiosII:inst|epcs_controller:the_epcs_controller|tornado_epcs_controller_ato m:the_tornado_epcs_controller_atom|internal_data0out" of type ASMI Block Error: Can't fit design in device Error: Quartus II Fitter was unsuccessful. 3 errors, 38 warnings Error: Processing ended: Sat Sep 30 14:40:01 2006 Error: Elapsed time: 00:00:11 Error: Quartus II Full Compilation was unsuccessful. 3 errors. I'm relatively new to Quartus II and SOPC builder and I can't figure out where the problem lies. My board is EP1C12 cyclone. My desing is very simple. It only contains the following components: - Nios II/e CPU with on-chip memory - One timer - EPCS flash controller - Active Serial Memory Interface - 2 input pins : sys_clk and sys-rest_n assigned pins 29 and 62 respectively. I don't know if I missed to add some important device, pin or interface to make it work. I would be greatful if there is some1 out there willing to help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif . Thanks in advanced.链接已复制
2 回复数
Hi Pegazaus
I'm not sure but for me it seems that active serial memory interface contradicts with epcs controller. Why do you need active serial interface? Do you know that you can read & write directly from epcs device through epcs controller? For more information see Nios II Software Developer’s Handbook alt_flash_open_dev(). Good luck!
