12745 ディスカッション
Eclipse 20.1 Fails to Program Nios unless Programmer Open in Quartus
James_B
新規コントリビューター II
1,990件の閲覧回数
I get the message "Unable to validate connection settings" in Eclipse 20.1 when attempting to program the Nios II processor on the DE10-Nano board when the FPGA section is already programmed.
If I have the programmer open in Quartus, then Eclipse can download the program successfully.
This doesn't make sense, can someone please explain? Is it that Eclipse 20.1 has to see a USB identifier or something that is enabled when the Quartus programming tool is open?
Thanks. James
0 件の賞賛
1 解決策
James_B
新規コントリビューター II
1,908件の閲覧回数
Aik,
Thanks for the feedback here. No, nothing more is required on this. The issue has been consistent. The solution has been to always open the JTAG programmer before opening Eclipse.
Thanks, James
元の投稿で解決策を見る
2 返答(返信)
aikeu
従業員
1,915件の閲覧回数
Hi James_B,
Sorry for late reply, do you still requires help on this?
Aik Eu
James_B
新規コントリビューター II
1,909件の閲覧回数
Aik,
Thanks, James
返信
