公告
12748 讨论
Eclipse error when trying to run Nios II program from sdram
Antoniogenn
初学者
6,048 次查看
Good evening, i have this problem where i try to run the "hello world" template in Eclipse after having designed a nios II system in Platform Designer configured with the sdram as the exception and reset vector. Eclipse says:
"Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Processor is already paused
Initializing CPU cache (if present)
OK
Downloading 02000000 ( 0%)
Downloading 02007250 (76%)
Downloaded 29KB in 0.4s (72.5KB/s)
Verifying 02000000 ( 0%)
Verify failed between address 0x2000000 and 0x20057B7
Leaving target processor paused"
I'm working on a DE0-Nano board.
These are the warnings i get in Quartus prime 18.1 during compilation:
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Warning (12251): Test.accelerometer_spi_0: Interrupt sender accelerometer_spi_0.interrupt is not connected to an interrupt receiver
Warning (10238): Verilog Module Declaration warning at altera_up_accelerometer_spi_auto_init_ctrl.v(51): ignored anonymous port(s) indicated by duplicate or dangling comma(s) in the port list for module "altera_up_accelerometer_spi_auto_init_ctrl"
Warning (10037): Verilog HDL or VHDL warning at test_new_sdram_controller_0.v(318): conditional expression evaluates to a constant
Warning (10037): Verilog HDL or VHDL warning at test_new_sdram_controller_0.v(328): conditional expression evaluates to a constant
Warning (10037): Verilog HDL or VHDL warning at test_new_sdram_controller_0.v(338): conditional expression evaluates to a constant
Warning (10037): Verilog HDL or VHDL warning at test_new_sdram_controller_0.v(682): conditional expression evaluates to a constant
Warning (10230): Verilog HDL assignment warning at test_accelerometer_spi_0.v(226): truncated value with size 32 to match size of target (8)
Warning (10230): Verilog HDL assignment warning at test_accelerometer_spi_0.v(241): truncated value with size 8 to match size of target (6)
Warning (10230): Verilog HDL assignment warning at altera_up_accelerometer_spi_auto_init_ctrl.v(137): truncated value with size 32 to match size of target (4)
Warning (10230): Verilog HDL assignment warning at altera_up_accelerometer_spi_serial_bus_controller.v(215): truncated value with size 32 to match size of target (5)
Warning (10230): Verilog HDL assignment warning at altera_up_accelerometer_spi_slow_clock_generator.v(110): truncated value with size 32 to match size of target (4)
Warning (10036): Verilog HDL or VHDL warning at altera_merlin_width_adapter.sv(283): object "in_write" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altera_merlin_width_adapter.sv(742): object "aligned_addr" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at altera_merlin_width_adapter.sv(743): object "aligned_byte_cnt" assigned a value but never read
Warning (12241): 5 hierarchies have connectivity warnings - see the Connectivity Checks report folder
Warning (13024): Output pins are stuck at VCC or GND
Warning (13410): Pin "new_sdram_controller_0_wire_cke" is stuck at VCC
Warning (21074): Design contains 1 input pin(s) that do not drive logic
Warning (15610): No output dependent on input pin "accelerometer_spi_0_external_interface_G_SENSOR_INT"
Warning (292013): Feature LogicLock is only available with a valid subscription license. You can purchase a software subscription to gain full access to this feature.
Warning (15714): Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details
Warning (176125): The input ports of the PLL test_altpll_1:altpll_1|test_altpll_1_altpll_u942:sd1|pll7 and the PLL test_altpll_0:altpll_0|test_altpll_0_altpll_m342:sd1|pll7 are mismatched, preventing the PLLs to be merged
Warning (176124): PLL test_altpll_1:altpll_1|test_altpll_1_altpll_u942:sd1|pll7 and PLL test_altpll_0:altpll_0|test_altpll_0_altpll_m342:sd1|pll7 have different input signals for input port ARESET
Critical Warning (176598): PLL "test_altpll_1:altpll_1|test_altpll_1_altpll_u942:sd1|pll7" input clock inclk[0] is not fully compensated because it is fed by a remote clock pin "Pin_R8"
Warning (332174): Ignored filter at test.sdc(9): CLOCK_50 could not be matched with a port
Warning (332049): Ignored create_clock at test.sdc(9): Argument <targets> is an empty collection
Info (332050): create_clock -period 20 [get_ports CLOCK_50]
Warning (332087): The master clock for this clock assignment could not be derived. Clock: altpll_0|sd1|pll7|clk[0] was not created.
Warning (332035): No clocks found on or feeding the specified source node: altpll_0|sd1|pll7|inclk[0]
Warning (332087): The master clock for this clock assignment could not be derived. Clock: altpll_1|sd1|pll7|clk[0] was not created.
Warning (332035): No clocks found on or feeding the specified source node: altpll_1|sd1|pll7|inclk[0]
Warning (332060): Node: clk_clk was determined to be a clock but was found without an associated clock assignment.
Info (13166): Register test_accelerometer_spi_0:accelerometer_spi_0|altera_up_accelerometer_spi_serial_bus_controller:Serial_Bus_Controller|s_serial_protocol.STATE_2_START_BIT is being clocked by clk_clk
Warning (332056): PLL cross checking found inconsistent PLL clock settings:
Warning (332056): Node: altpll_0|sd1|pll7|clk[0] was found missing 1 generated clock that corresponds to a base clock with a period of: 20.000
Warning (332056): Node: altpll_1|sd1|pll7|clk[0] was found missing 1 generated clock that corresponds to a base clock with a period of: 20.000
Warning (176250): Ignoring invalid fast I/O register assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
Warning (176251): Ignoring some wildcard destinations of fast I/O register assignments
Info (176252): Wildcard assignment "Fast Output Enable Register=ON" to "oe" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[9]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[8]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[7]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[6]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[5]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[4]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[3]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[2]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[1]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[15]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[14]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[13]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[12]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[11]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[10]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_data[0]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_cmd[2]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_cmd[1]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Info (176252): Wildcard assignment "Fast Output Register=ON" to "m_cmd[0]" matches multiple destination nodes -- some destinations are not valid targets for this assignment
Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
Warning (169177): 20 pins must meet Intel FPGA requirements for 3.3-, 3.0-, and 2.5-V interfaces. For more information, refer to AN 447: Interfacing Cyclone IV E Devices with 3.3/3.0/2.5-V LVTTL/LVCMOS I/O Systems.
Info (169178): Pin accelerometer_spi_0_external_interface_G_SENSOR_INT uses I/O standard 3.3-V LVTTL at M2
Info (169178): Pin accelerometer_spi_0_external_interface_I2C_SDAT uses I/O standard 3.3-V LVTTL at F1
Info (169178): Pin new_sdram_controller_0_wire_dq[0] uses I/O standard 3.3-V LVTTL at G2
Info (169178): Pin new_sdram_controller_0_wire_dq[1] uses I/O standard 3.3-V LVTTL at G1
Info (169178): Pin new_sdram_controller_0_wire_dq[2] uses I/O standard 3.3-V LVTTL at L8
Info (169178): Pin new_sdram_controller_0_wire_dq[3] uses I/O standard 3.3-V LVTTL at K5
Info (169178): Pin new_sdram_controller_0_wire_dq[4] uses I/O standard 3.3-V LVTTL at K2
Info (169178): Pin new_sdram_controller_0_wire_dq[5] uses I/O standard 3.3-V LVTTL at J2
Info (169178): Pin new_sdram_controller_0_wire_dq[6] uses I/O standard 3.3-V LVTTL at J1
Info (169178): Pin new_sdram_controller_0_wire_dq[7] uses I/O standard 3.3-V LVTTL at R7
Info (169178): Pin new_sdram_controller_0_wire_dq[8] uses I/O standard 3.3-V LVTTL at T4
Info (169178): Pin new_sdram_controller_0_wire_dq[9] uses I/O standard 3.3-V LVTTL at T2
Info (169178): Pin new_sdram_controller_0_wire_dq[10] uses I/O standard 3.3-V LVTTL at T3
Info (169178): Pin new_sdram_controller_0_wire_dq[11] uses I/O standard 3.3-V LVTTL at R3
Info (169178): Pin new_sdram_controller_0_wire_dq[12] uses I/O standard 3.3-V LVTTL at R5
Info (169178): Pin new_sdram_controller_0_wire_dq[13] uses I/O standard 3.3-V LVTTL at P3
Info (169178): Pin new_sdram_controller_0_wire_dq[14] uses I/O standard 3.3-V LVTTL at N3
Info (169178): Pin new_sdram_controller_0_wire_dq[15] uses I/O standard 3.3-V LVTTL at K1
Info (169178): Pin clk_clk uses I/O standard 3.3-V LVTTL at R8
Info (169178): Pin reset_reset_n uses I/O standard 3.3-V LVTTL at B9
0 项奖励
1 解答
wwanalim_intel
5,835 次查看
It is not wrong.
You may check on this similar previous case -
https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Can-t-get-DE0-nano-board-to-boot-from-EPCS-with-NIOSII-code/m-p/698479
Probably can help you out. On the reply also got one design that you can try. Hope this will work on your side
Thank you.
Fathulnaim
在原帖中查看解决方案
0 项奖励
8 回复数
wwanalim_intel
5,964 次查看
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
0 项奖励
wwanalim_intel
5,907 次查看
Hi Antonio,
Based on the image of your platform designer connection, it seems you did not connect the clock.
Is there any reason for that?
As I am referring here, it seems there is a connection for the clock.
Perhaps you can take a look at that too by following below link.
https://ftp.intel.com/Public/Pub/fpgaup/pub/Teaching_Materials/current/Tutorials/Verilog/DE2-115/Using_the_SDRAM.pdf
Thank you.
Fathulnaim
0 项奖励
Antoniogenn
初学者
5,887 次查看
I set the clock as an input for the PLL only and then I used the PLL clock outputs for the rest of the system. Is it wrong?
0 项奖励
wwanalim_intel
5,836 次查看
It is not wrong.
Thank you.
Fathulnaim
0 项奖励
Antoniogenn
初学者
5,793 次查看
Thank you, but i have already tried that design and it works, but when i try to replicate it from the ground up (the exact same design) it no longer works, i'm trying to figure out why
0 项奖励
wwanalim_intel
5,718 次查看
Hi Antonio,
Glad to hear that the design work. May I know any reason you did not want to use that design?
0 项奖励
Antoniogenn
初学者
5,697 次查看
I used a C code in Eclipse that didn't work so i tought there was something wrong with the example but now i've used the example DE0_NANO_SOPC_demo and everything went ok so i guess we can mark this as solved.
0 项奖励
wwanalim_intel
5,647 次查看
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
0 项奖励
回复
