Encrypted VHDL file
I recently received Nios-II update package. When trying to open
a VHDL source in cpu.vhd, I got the following message.
"Can't open encrypted file "C:\altera\kits\nios2\examples\vhdl
niosII_stratix_1s10\standard\cpu.vhd" -- license file support
for this file includes compilation support, but does not include
viewing support"
I am using Quartus-II version 4.2 with two entries in the
"Licensed AMPP/MegaCore functions" listing. Note that I have
no problem viewing other VHDL files in the same directory.
I sent email to Altera for help but have not heard back from
them for a week now. Well, I actually got this lame reply today.
> Date: Fri, 25 Feb 2005 08:10:50 -0800
> Subject: RE: your mail
> Are you still having problems? Have you tried our customer support
> e-mail line? Did you try to install the license twice?
> We want to help you.
Can anyone help?
Angkul
The Nios II CPU is encrypted by design... having an ordinary license to use Quartus/Nios II does not remove this encryption. Note that RTL simulation support is provided.
Thanks for a quick response. Does it mean that I cannot add anything to Nios-II CPU?
I added a branch predictor in Nios-I and would like to test it on Nios-II. What additional
license do I need? Note that I already have two licenses for Megacore Functions.
I am on the engineering side now so I'm not really sure how we handle license requests for the non-encrypted core (as is done for other IP as you indicate). My reccomendation would be to talk to your FAE/sales person about it.
BTW: The Nios II/f core does include branch prediction. I am not well studied on how this is actually implemented but I recall that there is a short discussion of it in the Nios II CPU documentation.
Hummm, you want to add a branch predictor. You could always just modify the perl code used
to generate the RTL. Look in c:\altera\kits\nios2\components\altera_nios2\*.pm.
Note that all the comments are stripped out (replaced with empty lines).
