SMTP
I would know if the OS uClinux can support the SMTP protocol and if there're some applications running with the support of this OS
Hi homer,
try: http://cvs.uclinux.org/cgi-bin/cvsweb.cgi/...ser/smtpclient/ (http://cvs.uclinux.org/cgi-bin/cvsweb.cgi/uclinux-dist/user/smtpclient/
From the README:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
This program is a minimal SMTP client that takes an email message body and passes it on to a SMTP server (default is the MTA on the local host). Since it is completely self-supporting, it is especially suitable for use in restricted environments.[/b]
--- Quote End ---
--Scott
many thanks Scott
homer http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Homer,
Have you tried it ?
Actually I can&#39;t compile it &#39;cause it doesn&#39;t find any uClibc
