I have a Nios II Embedded Evaluation Kit and wanted to try uClinux with frame buffer on it. (Followed the instruction on http://www.nioswiki.com/operatingsystems/uclinux/framebuffer). The SOF and PTF files are for the Standard System (http://www.nioswiki.com/nios2embeddedevaluationkit) I got the following error message refering to altfb.c: /home/rask/nios2-linux/linux-2.6/drivers/video/console/fbcon.c: In function `fbcon_init': /home/rask/nios2-linux/linux-2.6/drivers/video/console/fbcon.c:1071: warning: statement with no effect /home/rask/nios2-linux/linux-2.6/drivers/video/console/fbcon.c:1073: warning: statement with no effect /home/rask/nios2-linux/linux-2.6/drivers/video/console/fbcon.c: In function `fbcon_set_disp': /home/rask/nios2-linux/linux-2.6/drivers/video/console/fbcon.c:1346: warning: statement with no effect /home/rask/nios2-linux/linux-2.6/drivers/video/console/fbcon.c:1348: warning: statement with no effect CC drivers/video/console/bitblit.o CC drivers/video/console/fonts.o CC drivers/video/console/font_8x16.o LD drivers/video/console/font.o CC drivers/video/console/softcursor.o LD drivers/video/console/built-in.o LD drivers/video/display/built-in.o CC drivers/video/altfb.o /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c: In function `altfb_mmap': /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c:87: warning: assignment makes integer from pointer without a cast /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c: In function `altfb_dma_start': /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c:191: error: `na_lcd_sgdma' undeclared (first use in this function) /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c:191: error: (Each undeclared identifier is reported only once /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c:191: error: for each function it appears in.) /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c: In function `altfb_probe': /home/rask/nios2-linux/linux-2.6/drivers/video/altfb.c:253: warning: passing arg 3 of `dma_alloc_coherent' from incompatible pointer type make[4]: *** [drivers/video/altfb.o] Fehler 1 make[3]: *** [drivers/video] Fehler 2 make[2]: *** [drivers] Fehler 2 make[1]: *** [sub-make] Fehler 2 make[1]: leaving directory '/home/rask/nios2-linux/linux-2.6' make: *** [linux] Fehler 1 Could anyone help me at this one? Thank you in advance. D.Link Copied
Please try this design and select "NEEK" platform in kernel config.
http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip - Hippo- Mark as New
Thank you Hippo.
As for frame buffer, your design worked out. Unfortunatly I got an error refering to atkbd.c: altps2 : base 88001420 irq 9 mice: PS/2 mouse device common for all mice ads7846 spi1.0: touchscreen, irq 4 input: ADS784x Touchscreen as /class/input/input0 TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. Freeing unused kernel memory: 1664k freed (0x20c000 - 0x3ab000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc -o noexec,nosuid,nodev Command: mount -t sysfs sysfs /sys -o noexec,nosuid,nodev Command: mount -t devpts devpts /dev/pts -o noexec,nosuid Command: mount -t usbfs none /proc/bus/usb atkbd.c: keyboard reset failed on altps2.0 mount: mounting none on /proc/bus/usb failed: No such file or directory Command: mkdir /var/tmp Command: mkdir /var/log Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo Command: cat /etc/motd Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ Execution Finished, Exiting Sash command shell (version 1.1.1) /> atkbd.c: keyboard reset failed on altps2.0 Due to using the keyboard won't work. Have you some advice on this one? Thanks. D.- Mark as New
It doesn't matter. Or you can connect a ps2 keyboard. You can still run nano-X if you configure it to "no keyboard", make user/microwin_clean; make .
Hi Hippo,
Same error occured when I was compiling Frame Buffer appliction for DE2-70 board. LD usr/built-in.o CC drivers/video/altfb.o /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c: In function `altfb_mmap': /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c:87: warning: assignment makes integer from pointer without a cast /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c: In function `altfb_dma_start': /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c:236: error: `na_vga_controller_0' undeclared (first use in this function) /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c:236: error: (Each undeclared identifier is reported only once /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c:236: error: for each function it appears in.) /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c:236: warning: initialization makes integer from pointer without a cast /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c: In function `altfb_probe': /home/muhammet/Desktop/nios2-linux/linux-2.6/drivers/video/altfb.c:253: warning: passing arg 3 of `dma_alloc_coherent' from incompatible pointer type make[4]: *** [drivers/video/altfb.o] Error 1 make[3]: *** [drivers/video] Error 2 make[2]: *** [drivers] Error 2 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/home/muhammet/Desktop/nios2-linux/linux-2.6' make: *** [linux] Error 1 ----------------------------------------- I dont findd the solution on the internet. Could you help me to solve problem? Thank You- Mark as New
Hi mmkaya
I've just had exactly the same error while trying to make a uClinux image for DE2 board, but adding microwindows. I've followed the configs mentioned on nioswiki.com/OperatingSystems/UClinux/FrameBuffer Did you finally succeed to do so ? Hope you can help me Thank you Flo- Mark as New
Hi Flo,
Yes,I have succedeed to run compiling after changing something according to other entries on the internet.It was six months ago so I can not remember the solution of error exactly.But I can say you can find the solution from google as I have done. If you cannot find any solution, give a me a word. I can make a try to that issue. Best Regards- Mark as New
Thank you mmkaya,
Actually I didn't found any solution from google. I've succedded by changing the name of the VGA controller in the SOPC Builder in Quartus : VGA_0 --> vga_controller_0 So the variable na_VGA_0 which was created becomes na_vga_controller_0 and then it works fine. Best regards
