bootstrap compiler
I don't know if it is the correct section of the forum for that question.
I have one question about the cross-compiling toolchain.
It is said in each documentation that we must create a bootstrap compiler then compile the c library then compile the full gcc compiler.
I wonder why we need the bootstrap compiler ?
Thank you
