12748 Discussions
Error accessing memory address
Hello everyone!First ,I should thanks Fischer for give me advice .now I have a problem need someone's help.
the problem is :
The execution of program is suspended because of error.
Warning:
Cannot insert breakpoint 1.
Error accessing memory address 0x100034c: (undocumented errno -1).
Cannot insert breakpoint 3.
Error accessing memory address 0x1000358: (undocumented errno -1).
this problem appears whem I debug the software on my hardware.please do me a favor.Thank you very much!!!!!
you should tell people a little more about your system
- NIOS VERSION ?
- QUARTUS VERSION ?
- DEVELOPMENT BOARD ?
is sample program running ?
- CUSTOM BOARD ?
- do you use external flash ,ram ?
- is a NIOS sample program running ?
- is a small testprogram runnning from onchip ram ?
- does programming works ?
- does a program from flash works ?
My tools are:
quartus4.2+niosII 1.1;stratix1s10 develop board;I make my own hardware image ,download it to stratix fpga, set up a software program,debug it in NIosII IDE.
use external flash,sram,eternet,sdram and on_chip ram....;data memory and progrm memory is sdram,which base address is 0x0100000.
In my program the function of printf can't work too.
you ask that "is a small testprogram runnning from onchip ram ? ".
I don't know .
my program dosen't work.the program dosen't work from flash.
"...I make my own hardware image ..."
does the board work with a predefined hardware and software
sample from altera ? could you debug, program such a sample ?
I only know the cyclone board, but I think it should be the same,
to check if your problem is perhaps the sdram, try to run
- your program from sram,
- a small testprogram fron onchip ram
check the settings of your cpu in sopc builder.
- reset address: flash
- exception address: onchip memory (in my case)
in system library set program and date memory to
sram or onchipmemory.
