12746 Discussions
Error from the tutorial of Generating and Compiling Cyclone V Preloader
SONG
Hi, I have an Error from the tutorial of Generating and Compiling Cyclone V Preloader.
the error message is here
C:\intelFPGA\18.0\embedded\host_tools\mentor\gnu\arm\baremetal\bin\arm-altera-eabi-ld.exe: cannot open map file u-boot-spl.map: Permission denied
Makefile:178: '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl/u-boot-spl' 타겟에 대한 명령이 실패했습니다
make[2]: *** [/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl/u-boot-spl] 오류 1
make[2]: 디렉터리 '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/spl' 나감
Makefile:611: 'spl/u-boot-spl.bin' 타겟에 대한 명령이 실패했습니다
make[1]: *** [spl/u-boot-spl.bin] 오류 2
make[1]: 디렉터리 '/cygdrive/c/intelFPGA/18.0/embedded/examples/hardware/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga' 나감
make: *** [uboot-socfpga/spl/u-boot-spl.bin] Error 2
How can I fix this error?
Abe
Valued Contributor II
The main issue may be due to permissions as the error describes:
" cannot open map file u-boot-spl.map: Permission denied"
Check if your working / code folders have requisite permissions - read/write before executing the make command. Also verify that you are not referencing another user's workspace which might be in read-only mode.
Did you run the command with super-user/root privilages (su make/ sudo make) try running it that way and check.
FawazJ_Altera
Try to run SoC EDS as Administrator and see if you can overcome this issue.
FawazJ_Altera
Does the note above helped you Abraham?
ABara8
Hello, I had this problem and cheking prepissions helped me. Files, extracted by untar had only read and exec premissions, so did parent folder
Sperber
I'm facing the same issue.
I tried to change permissions of my code directory to 777
I also tried to change windows permissions for this file.
Can you explain in detail, what worked for you?
Thank you very much.
Mahsheed
Please follow the below steps
1) If you have reached to this point, then  there will be a folder named 'uboot-socfpga' in spl-bsp folder.
2) Go to properties
3) Go to security tab
4) Give full control to the account and System
5) Click on Advanced
6) tick the checkbox for replace all child object permission entries
7) Run make command again
If you still face any errors, feel free to contact me.
