12748 Discussions
Error: s0: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.b
SThor8
Hi
Windows 10 Pro
Version 2004
OS buid 19041.330
Quartus prime version 20.1 Build 711 standard edition
The platform designer generates the following error.
Error: s0: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
When the platform designer tries to generate HDL code
I have tried to both switch on and off the  “Windows Subsystem for Linux” according to
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2018/error--s0--error-during-execution-of---c--intelfpga-xx-x-quartus.html
but no luck (seems odd to switch off “Windows Subsystem for Linux” when the bat file Nios II Command Shell.bat is using wsl).
I can from a command prompt execute the bat file (“Windows Subsystem for Linux”  on)
C:\intelFPGA\20.1\nios2eds>
C:\intelFPGA\20.1\nios2eds>"Nios II Command Shell.bat"
Altera Nios2 Command Shell
Version 20.1, Build 711
stefan@DESKTOP-MH7IPN4:/mnt/c/intelFPGA/20.1/nios2eds$ exit
exit
But the platform designer can not execute it, any ideas ?
Info: p0: "ddr3" instantiated altera_mem_if_ddr3_phy_core "p0"
Info: m0: "ddr3" instantiated altera_mem_if_ddr3_afi_mux "m0"
Error: s0: Execution of command "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: s0: /mnt/c/intelfpga/20.1/quartus/bin64/uniphy_mcc.exe -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../system_ddr3_s0_AC_ROM.hex -inst_rom ../system_ddr3_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0001000110001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100110000 -DAC_ROM_MR1=0000001000100 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000000001000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001001001001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001011001000 -DAC_ROM_MR1_MIRR=0000000100100 -DAC_ROM_MR2_MIRR=0000000010000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=1 -DFULL_RATE=0 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=0
Error: s0: UniPHY Sequencer Microcode Compiler
Error: s0: Copyright (C) 2020  Intel Corporation. All rights reserved.
Error: s0: Info: Reading sequencer_mc/ac_rom.s ...
Error: s0: Info: Reading sequencer_mc/inst_rom.s ...
Is it possible to get the content from the stderr.txt files ?
Nikolay_Rognlien
Hi Intel.
Can you please give an update on the status on the UniPHY generate issue?
Are there patches available for the various Quartus releases starting from 19.1 that fix the issues?
Nikolay
FilipMiler
Unfortunately this problem reappeared in version 21.1
KennyTan_Altera
kindly report a new forum on this. thanks
Nikolay_Rognlien
Hi Filip.
This patch solved the problem on my computer:
https://www.intel.com/content/www/us/en/support/programmable/articles/000088789.html
It did however not solve it on another customer's computer, so I would be interested to hear your result...
/Nikolay
FilipMiler
Hi. It works on my two computers with Windows 10 21H2 and Ubuntu 18.04 on WSL 1. Thanks.
ovguozgur
You are the best. This soluiton works for me too.
