Example for DK-3SL150
Hello everyone,
I'm looking for an example for the development system DK-DSP-3SL150 including a Nios system.
The available example "stratixIII_3sl150_dev_niosII_standard" does not contain a schematic with Top_Level (or so I seem to have understood).
I d'like make a Simple Socket Server application that uses the triple speed ethernet. But I need an example with a top level schematic (. Bdf) to acquire the data read from the A / D converter connected to the HSMC.
Where can I find an example (even without the A / D converters assigment)?.
Thanks Fabio Pollastrone
Sorry,
I have found the solution.
I have create the simbol from the file stratixIII_3sl150_dev_niosII_standard.v. so that I have the sopc with the correct i/o pin name.
