12748 Discussions
FAT support in prelaoder: compilation issues
I'm trying to build preloader with FAT support and compilation process fails. I've checked SD/MMC boot and FAT support. In files lowlevel_init.S and spl.c there are some undifined references: __sdram_stack_start, __sdram_stack_end, __bss_fat_start, __bss_fat_end, __malloc_fat_start, __malloc_fat_end. So make process exit with failure. How can I solve this problem?
Thank you for the link. Matter of fact the compilation fails when FAT SUPPORT and EXE ON FPGA are checked together. It is strange because what if I wanna boot preloader from FPGA OCRAM and then load my app from SD/MMC FAT partition. It is not forbidden directly somewhere in documentation as I know.
this is preloader make file error or application compilation error?
