- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi~
Fltk can run. I Change my my Makefile to do it. Thank pcfantasy and Kazuyasu. Tingming My Makefile --- Quote Start --- EXEC = feverscan_gui OBJS = main.o MICROLIB = ~/nios2-linux/uClinux-dist/user/microwin INC = -I .. INC += -I $(MICROLIB)/nxlib/fltk-1.1.8rc3 # INC += -I $(MICROLIB)/nxlib/fltk-1.1.8rc3/FL LIB += -L $(MICROLIB)/nxlib/fltk-1.1.8rc3/lib LIB += -L $(MICROLIB)/src/lib LIB += -L $(MICROLIB)/nxlib/nxlib-0.45 LDLIBS += -lfltk -lnx11 -lnano-X -lpthread -lm all: $(EXEC) $(EXEC): $(OBJS) nios2-linux-gnu-g++ -o $(EXEC) $(OBJS) $(LDLIBS) $(LIB) romfs: $(ROMFSINST) /bin/$(EXEC) clean: -rm -f $(EXEC) *.elf *.gdb *.o main.o: main.cxx setup.cxx nios2-linux-gnu-g++ $(INC) -c main.cxx setup.cxx --- Quote End --- My setup.h --- Quote Start --- // generated by Fast Light User Interface Designer (fluid) version 1.0108 # ifndef setup_h # define setup_h # include <FL/Fl.H> # include <FL/Fl_Window.H> # include <FL/Fl_Group.H> # include <FL/Fl_Input.H> # include <FL/Fl_Spinner.H> # include <FL/Fl_Box.H> # include <FL/Fl_Button.H> # include <FL/Fl_Value_Output.H> class GuiWindow : public Fl_Window { void _GuiWindow(); public: GuiWindow(int X, int Y, int W, int H, const char *L = 0); GuiWindow(int W, int H, const char *L = 0); Fl_Group *Tab_1; Fl_Input *height0; Fl_Input *width0; Fl_Input *width1; Fl_Input *width2; Fl_Input *width3; Fl_Spinner *height1; Fl_Spinner *height2; Fl_Spinner *height3; Fl_Group *Tab_2; Fl_Group *Tab_3; Fl_Button *Tab1; Fl_Button *Tab2; Fl_Button *Tab3; Fl_Value_Output *IntensityShowBox; Fl_Value_Output *TempatureShowBox; }; # endif --- Quote End --- My setup.cxx --- Quote Start --- // generated by Fast Light User Interface Designer (fluid) version 1.0108 # include "setup.h" # include<stdio.h> # include<stdlib.h> GuiWindow::GuiWindow(int X, int Y, int W, int H, const char *L) : Fl_Window(X, Y, W, H, L) { _GuiWindow(); } GuiWindow::GuiWindow(int W, int H, const char *L) : Fl_Window(0, 0, W, H, L) { clear_flag(16); _GuiWindow(); } void GuiWindow::_GuiWindow() { this->box(FL_UP_BOX); this->color((Fl_Color)220); this->selection_color(FL_BACKGROUND_COLOR); this->labeltype(FL_NO_LABEL); this->labelfont(0); this->labelsize(14); this->labelcolor(FL_FOREGROUND_COLOR); this->align(FL_ALIGN_TOP); this->when(FL_WHEN_NEVER); { Tab_1 = new Fl_Group(150, 35, 500, 150); Tab_1->box(FL_PLASTIC_UP_FRAME); Tab_1->color((Fl_Color)132); Tab_1->selection_color((Fl_Color)220); Tab_1->labelcolor(FL_BLACK); Tab_1->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE); Tab_1->when(FL_WHEN_NEVER); { height0 = new Fl_Input(215, 45, 120, 25, "height0 :"); height0->type(5); height0->box(FL_PLASTIC_THIN_DOWN_BOX); } // Fl_Input* height0 { width0 = new Fl_Input(440, 45, 120, 25, "width0 :"); width0->type(5); } // Fl_Input* width0 { width1 = new Fl_Input(440, 77, 120, 25, "width1 :"); width1->type(2); } // Fl_Input* width1 { width2 = new Fl_Input(440, 105, 120, 25, "width2 :"); width2->type(5); } // Fl_Input* width2 { width3 = new Fl_Input(440, 135, 120, 25, "width3 :"); width3->type(1); } // Fl_Input* width3 { height1 = new Fl_Spinner(215, 75, 120, 25, "height1 :"); height1->maximum(100000); height1->value(1); } // Fl_Spinner* height1 { height2 = new Fl_Spinner(215, 105, 120, 25, "height2 :"); height2->maximum(100000); height2->value(1); } // Fl_Spinner* height2 { height3 = new Fl_Spinner(215, 135, 120, 25, "height3 :"); height3->maximum(100000); height3->value(1); } // Fl_Spinner* height3 Tab_1->end(); } // Fl_Group* Tab_1 { Tab_2 = new Fl_Group(150, 35, 500, 150); Tab_2->box(FL_PLASTIC_UP_FRAME); Tab_2->color(FL_MAGENTA); Tab_2->selection_color((Fl_Color)220); Tab_2->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE); Tab_2->when(FL_WHEN_NEVER); Tab_2->hide(); { Fl_Box* o = new Fl_Box(150, 35, 500, 150, "label2"); o->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE); } // Fl_Box* o Tab_2->end(); } // Fl_Group* Tab_2 { Tab_3 = new Fl_Group(150, 35, 500, 150); Tab_3->box(FL_PLASTIC_UP_FRAME); Tab_3->color((Fl_Color)80); Tab_3->selection_color((Fl_Color)220); Tab_3->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE); Tab_3->when(FL_WHEN_NEVER); Tab_3->hide(); { Fl_Box* o = new Fl_Box(150, 35, 500, 150, "label3"); o->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE); } // Fl_Box* o Tab_3->end(); } // Fl_Group* Tab_3 { Tab1 = new Fl_Button(150, 15, 70, 20, "Tab 1"); Tab1->box(FL_PLASTIC_UP_BOX); Tab1->color((Fl_Color)48); } // Fl_Button* Tab1 { Tab2 = new Fl_Button(220, 15, 70, 20, "Tab 2"); Tab2->box(FL_PLASTIC_UP_BOX); } // Fl_Button* Tab2 { Tab3 = new Fl_Button(290, 15, 70, 20, "Tab 3"); Tab3->box(FL_PLASTIC_UP_BOX); } // Fl_Button* Tab3 { IntensityShowBox = new Fl_Value_Output(30, 75, 100, 25); IntensityShowBox->maximum(300); IntensityShowBox->value(180); } // Fl_Value_Output* IntensityShowBox { TempatureShowBox = new Fl_Value_Output(30, 110, 100, 25); TempatureShowBox->maximum(100); TempatureShowBox->value(37.6); } // Fl_Value_Output* TempatureShowBox clear_border(); end(); resizable(this); } --- Quote End --- My main.cxx --- Quote Start --- # include <stdio.h> # include <stdlib.h> # include "setup.cxx" # include <unistd.h> # include <pthread.h> # include <string.h> # include <fcntl.h> # include <termios.h> GuiWindow *g; static void loop_tab2(void*) { } int main(int argc, char **argv) { GuiWindow *gw ; Fl::visual(FL_RGB); gw = new GuiWindow(0,0,1365,200); gw->show(); g = gw; g->Tab_1->hide(); g->Tab_2->hide(); g->Tab_3->hide(); return Fl::run(); } --- Quote End ---링크가 복사됨
2 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
//#include "setup.cxx"
put setup.cxx in setup.h try it.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- I try to build a GUI Interface using FLTK. I have a code which can run on nios-linux nommu version(20090730) However, I can't use the same code in MMU version(20100621) I think the problem is my Makefile, I can't involve all the libraries. Compiler will generate (cannot find -lfltk, -lnano-x, -lX11) --- Quote End --- Maybe you need dynamic link libraries 'libnano-x.so', 'libX11.so' and so on. You can make 'libX11.so' in the folder 'nios2-linux/uClinux-dist/user/microwin/nxlib/nxlib-0.45'. And please refer my post. http://www.alteraforum.com/forum/showpost.php?p=74596&postcount=13 Kazu
