FLTK Problem
Hi~
Fltk can run.
I Change my my Makefile to do it.
Thank pcfantasy and Kazuyasu.
Tingming
My Makefile
--- Quote Start ---
EXEC = feverscan_gui
OBJS = main.o
MICROLIB = ~/nios2-linux/uClinux-dist/user/microwin
INC = -I ..
INC += -I $(MICROLIB)/nxlib/fltk-1.1.8rc3
# INC += -I $(MICROLIB)/nxlib/fltk-1.1.8rc3/FL
LIB += -L $(MICROLIB)/nxlib/fltk-1.1.8rc3/lib
LIB += -L $(MICROLIB)/src/lib
LIB += -L $(MICROLIB)/nxlib/nxlib-0.45
LDLIBS += -lfltk -lnx11 -lnano-X -lpthread -lm
all: $(EXEC)
$(EXEC): $(OBJS)
nios2-linux-gnu-g++ -o $(EXEC) $(OBJS) $(LDLIBS) $(LIB)
romfs:
$(ROMFSINST) /bin/$(EXEC)
clean:
-rm -f $(EXEC) *.elf *.gdb *.o
main.o: main.cxx setup.cxx
nios2-linux-gnu-g++ $(INC) -c main.cxx setup.cxx
--- Quote End ---
My setup.h
--- Quote Start ---
// generated by Fast Light User Interface Designer (fluid) version 1.0108
# ifndef setup_h
# define setup_h
# include <FL/Fl.H>
# include <FL/Fl_Window.H>
# include <FL/Fl_Group.H>
# include <FL/Fl_Input.H>
# include <FL/Fl_Spinner.H>
# include <FL/Fl_Box.H>
# include <FL/Fl_Button.H>
# include <FL/Fl_Value_Output.H>
class GuiWindow : public Fl_Window {
void _GuiWindow();
public:
GuiWindow(int X, int Y, int W, int H, const char *L = 0);
GuiWindow(int W, int H, const char *L = 0);
Fl_Group *Tab_1;
Fl_Input *height0;
Fl_Input *width0;
Fl_Input *width1;
Fl_Input *width2;
Fl_Input *width3;
Fl_Spinner *height1;
Fl_Spinner *height2;
Fl_Spinner *height3;
Fl_Group *Tab_2;
Fl_Group *Tab_3;
Fl_Button *Tab1;
Fl_Button *Tab2;
Fl_Button *Tab3;
Fl_Value_Output *IntensityShowBox;
Fl_Value_Output *TempatureShowBox;
# endif
--- Quote End ---
My setup.cxx
--- Quote Start ---
# include "setup.h"
# include<stdio.h>
# include<stdlib.h>
GuiWindow::GuiWindow(int X, int Y, int W, int H, const char *L)
: Fl_Window(X, Y, W, H, L) {
_GuiWindow();
GuiWindow::GuiWindow(int W, int H, const char *L)
: Fl_Window(0, 0, W, H, L) {
clear_flag(16);
_GuiWindow();
void GuiWindow::_GuiWindow() {
this->box(FL_UP_BOX);
this->color((Fl_Color)220);
this->selection_color(FL_BACKGROUND_COLOR);
this->labeltype(FL_NO_LABEL);
this->labelfont(0);
this->labelsize(14);
this->labelcolor(FL_FOREGROUND_COLOR);
this->align(FL_ALIGN_TOP);
this->when(FL_WHEN_NEVER);
{ Tab_1 = new Fl_Group(150, 35, 500, 150);
Tab_1->box(FL_PLASTIC_UP_FRAME);
Tab_1->color((Fl_Color)132);
Tab_1->selection_color((Fl_Color)220);
Tab_1->labelcolor(FL_BLACK);
Tab_1->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE);
Tab_1->when(FL_WHEN_NEVER);
{ height0 = new Fl_Input(215, 45, 120, 25, "height0 :");
height0->type(5);
height0->box(FL_PLASTIC_THIN_DOWN_BOX);
} // Fl_Input* height0
{ width0 = new Fl_Input(440, 45, 120, 25, "width0 :");
width0->type(5);
} // Fl_Input* width0
{ width1 = new Fl_Input(440, 77, 120, 25, "width1 :");
width1->type(2);
} // Fl_Input* width1
{ width2 = new Fl_Input(440, 105, 120, 25, "width2 :");
width2->type(5);
} // Fl_Input* width2
{ width3 = new Fl_Input(440, 135, 120, 25, "width3 :");
width3->type(1);
} // Fl_Input* width3
{ height1 = new Fl_Spinner(215, 75, 120, 25, "height1 :");
height1->maximum(100000);
height1->value(1);
} // Fl_Spinner* height1
{ height2 = new Fl_Spinner(215, 105, 120, 25, "height2 :");
height2->maximum(100000);
height2->value(1);
} // Fl_Spinner* height2
{ height3 = new Fl_Spinner(215, 135, 120, 25, "height3 :");
height3->maximum(100000);
height3->value(1);
} // Fl_Spinner* height3
Tab_1->end();
} // Fl_Group* Tab_1
{ Tab_2 = new Fl_Group(150, 35, 500, 150);
Tab_2->box(FL_PLASTIC_UP_FRAME);
Tab_2->color(FL_MAGENTA);
Tab_2->selection_color((Fl_Color)220);
Tab_2->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE);
Tab_2->when(FL_WHEN_NEVER);
Tab_2->hide();
{ Fl_Box* o = new Fl_Box(150, 35, 500, 150, "label2");
o->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE);
} // Fl_Box* o
Tab_2->end();
} // Fl_Group* Tab_2
{ Tab_3 = new Fl_Group(150, 35, 500, 150);
Tab_3->box(FL_PLASTIC_UP_FRAME);
Tab_3->color((Fl_Color)80);
Tab_3->selection_color((Fl_Color)220);
Tab_3->align(FL_ALIGN_CENTER|FL_ALIGN_INSIDE);
Tab_3->when(FL_WHEN_NEVER);
Tab_3->hide();
{ Fl_Box* o = new Fl_Box(150, 35, 500, 150, "label3");
} // Fl_Box* o
Tab_3->end();
} // Fl_Group* Tab_3
{ Tab1 = new Fl_Button(150, 15, 70, 20, "Tab 1");
Tab1->box(FL_PLASTIC_UP_BOX);
Tab1->color((Fl_Color)48);
} // Fl_Button* Tab1
{ Tab2 = new Fl_Button(220, 15, 70, 20, "Tab 2");
Tab2->box(FL_PLASTIC_UP_BOX);
} // Fl_Button* Tab2
{ Tab3 = new Fl_Button(290, 15, 70, 20, "Tab 3");
Tab3->box(FL_PLASTIC_UP_BOX);
} // Fl_Button* Tab3
{ IntensityShowBox = new Fl_Value_Output(30, 75, 100, 25);
IntensityShowBox->maximum(300);
IntensityShowBox->value(180);
} // Fl_Value_Output* IntensityShowBox
{ TempatureShowBox = new Fl_Value_Output(30, 110, 100, 25);
TempatureShowBox->maximum(100);
TempatureShowBox->value(37.6);
} // Fl_Value_Output* TempatureShowBox
clear_border();
end();
resizable(this);
--- Quote End ---
My main.cxx
--- Quote Start ---
# include <stdio.h>
# include <stdlib.h>
# include "setup.cxx"
# include <unistd.h>
# include <pthread.h>
# include <string.h>
# include <fcntl.h>
# include <termios.h>
GuiWindow *g;
static void loop_tab2(void*)
int main(int argc, char **argv) {
GuiWindow *gw ;
Fl::visual(FL_RGB);
gw = new GuiWindow(0,0,1365,200);
gw->show();
g = gw;
g->Tab_1->hide();
g->Tab_2->hide();
g->Tab_3->hide();
return Fl::run();
--- Quote End ---
//#include "setup.cxx"
put setup.cxx in setup.h
try it.
--- Quote Start ---
I try to build a GUI Interface using FLTK.
I have a code which can run on nios-linux nommu version(20090730)
However, I can't use the same code in MMU version(20100621)
I think the problem is my Makefile,
I can't involve all the libraries.
Compiler will generate (cannot find -lfltk, -lnano-x, -lX11)
--- Quote End ---
Maybe you need dynamic link libraries 'libnano-x.so', 'libX11.so' and so on. You can make 'libX11.so' in the folder 'nios2-linux/uClinux-dist/user/microwin/nxlib/nxlib-0.45'. And please refer my post.
http://www.alteraforum.com/forum/showpost.php?p=74596&postcount=13
Kazu
