- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I'm doing a project with Arria V SoC using the HPS and FPGA parts. In the FPGA, I have a custom IP with AXI Master interface on it. This IP should read and write from/to the SDRAM directly. However, I can only do read operation! The write operation does not work. The data in SDRAM is provided by HPS (running Linux). For now, I'm using /dev/mem to write the data to the SDRAM. Using the same method, I found that the data is never written from FPGA. 1. Can you help me with this issue? Anyone has already done a work using AXI and SDRAM? 2. In Qsys, my AXI master should be connected to the SDRAM, right? Did I do some mistake? I connect it to f2h_sdram0_data, not f2h_axi_slave on hps_0. 3. Is there any configuration that I need to do in the AXI to perform read and write? Thank you so much for your help.Link copiado
4 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Never mind. Found it.
--- Quote Start --- Hello, I'm doing a project with Arria V SoC using the HPS and FPGA parts. In the FPGA, I have a custom IP with AXI Master interface on it. This IP should read and write from/to the SDRAM directly. However, I can only do read operation! The write operation does not work. The data in SDRAM is provided by HPS (running Linux). For now, I'm using /dev/mem to write the data to the SDRAM. Using the same method, I found that the data is never written from FPGA. 1. Can you help me with this issue? Anyone has already done a work using AXI and SDRAM? 2. In Qsys, my AXI master should be connected to the SDRAM, right? Did I do some mistake? I connect it to f2h_sdram0_data, not f2h_axi_slave on hps_0. 3. Is there any configuration that I need to do in the AXI to perform read and write? Thank you so much for your help. --- Quote End ---- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
--- Quote Start --- Never mind. Found it. --- Quote End --- If you post your solution it can help others in the future, who will most likely be very grateful!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Perhaps you can refer to the following design example on using the FPGA to HPS SDRAM bridge: https://rocketboards.org/foswiki/projects/cyclevsocsdramperformanceexampledesign Regards, ccthum (This message was posted on behalf of Intel Corporation)- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I am reopenning this issue because I am having the same problem.
Only my read interface is working but the write doesn't work.
If someone knows the solution I would be thankful.
thank you for your help
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
