- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I'm having trouble with the Nios V Command Shell; specifically, I cannot start the shell (niosv-shell.exe) or the RiscFree IDE. Sometimes the program starts, and sometimes it does not.
Operating system: Windows 10 19045.5737 version 22H2.
Tool: Quartus Prime Pro 23.4
I'm getting an application error 0xc0000142: I've already reinstalled the Quartus tool a few times.
Also followed the steps from the link below.
https://thegeekpage.com/how-to-solve-application-error-0xc0000142-in-windows-10/
still getting the same issue.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Sorry to hear that didn't help.
Could you please try running 'quartus_sh -s' to see if Quartus starts successfully?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @DivyaG_Altera,
Unfortunately issues are still persisting, can you please advise on above?
Hope to hear from you soon.
Best Wishes
BB
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @DivyaG_Altera,
Any advise for from the above latest response?
Eager to hear from you soon.
Best Wishes
BB
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Prashant,
We attempted to reproduce this issue on a Windows 10 machine but have not been successful so far.
The Tools team recommends trying standard Python 3.8.10, as it closely matches the Python 3.8.18 version used by quartus_py in Quartus 23.4.
Download Python 64bit 3.8.10 from:
https://www.python.org/ftp/python/3.8.10/python-3.8.10-amd64.exe
Run the Python installer after download completes. Select Custom Installation
uncheck Documentation
uncheck tcl/tk and IDLE
uncheck Python test suite
Click Next
Uncheck Associate files with Python (requires the py launcher)
Uncheck Create shortcuts for installed applications
Select Customized install location and use this path or any convenient short path.
c:\a\Python\Python38
Click install
Close
From command prompt:
cd <quartus installation>\niosv\bin\niosv-shell-files\
c:\a\Python\Python38\python main.py
As suggested above, set the PATH to be the minimal and run quartus_py
Please let us know if this makes any difference.
Divya
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Click Next
Click install
Close
As suggested above, set the PATH to minimal, we recommend installation to be at default c:\intelFPGA_pro\23.4 and run NIOS V shell.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi BB and Divya,
We have installed Python 3.8.10 as per your suggestion.
Initially, everything was working well — the Nios V console functioned correctly even after multiple system restarts.
However, today when I powered on my PC, I observed that the same error has reappeared.
Prashant Gohel
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @prashant_gohel,
Good day, just following up on the previous clarification.
By any chances did you managed to look into it?
Best Wishes
BB
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @prashant_gohel,
As previously installing Python 3.8.10 did managed to fixed the issues until recently.
Which suspecting that there might be some corruption in the python end.
Did you managed to reinstalled as mention steps above to see if that works?
And recent is there any changes toward your system?
Best Wishes
BB
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for testing it out. Let us know if re-installing Python makes any difference.
Meanwhile, our tools team have created a test setup with Windows 10 to list out the list of DLLs that are expected to be present for niosv-shell / qyartus_py. To find this on your Windows machine, use this Microsoft utility : https://learn.microsoft.com/en-us/sysinternals/downloads/listdlls
To run this, first launch niosv shell : c:\intelFPGA_pro\23.4\niosv\bin\niosv-shell.exe
Then from a new cmd shell, run : Listdlls.exe quartus_py.exe > out.txt
You can compare the DLLs listed in 'out.txt' with the list provided below by our tools team. For convenience, we've categorized the DLLs based on their source.
Below is the list of DLLs provided by Windows:
Base Size Path
0x00000000072b0000 0x1f8000 C:\WINDOWS\SYSTEM32\ntdll.dll
0x0000000005750000 0xc2000 C:\WINDOWS\System32\KERNEL32.DLL
0x00000000049f0000 0x2ff000 C:\WINDOWS\System32\KERNELBASE.dll
0x00000000051d0000 0x100000 C:\WINDOWS\System32\ucrtbase.dll
0x0000000003cf0000 0x3b000 C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
0x0000000007260000 0x8000 C:\WINDOWS\System32\PSAPI.DLL
0x00000000058b0000 0x6b000 C:\WINDOWS\System32\WS2_32.dll
0x00000000070c0000 0x19d000 C:\WINDOWS\System32\USER32.dll
0x0000000005f70000 0x123000 C:\WINDOWS\System32\RPCRT4.dll
0x0000000004f40000 0x22000 C:\WINDOWS\System32\win32u.dll
0x0000000006280000 0xaf000 C:\WINDOWS\System32\ADVAPI32.dll
0x0000000005920000 0x9e000 C:\WINDOWS\System32\msvcrt.dll
0x00000000063c0000 0x2b000 C:\WINDOWS\System32\GDI32.dll
0x00000000052d0000 0x9f000 C:\WINDOWS\System32\sechost.dll
0x0000000004d90000 0x11a000 C:\WINDOWS\System32\gdi32full.dll
0x0000000005540000 0x55000 C:\WINDOWS\System32\SHLWAPI.dll
0x00000000049c0000 0x27000 C:\WINDOWS\System32\bcrypt.dll
0x0000000004cf0000 0x9d000 C:\WINDOWS\System32\msvcp_win.dll
0x00000000f5a10000 0x1d000 C:\WINDOWS\SYSTEM32\MPR.dll
0x00000000f2650000 0x19000 C:\WINDOWS\SYSTEM32\NETAPI32.dll
0x0000000005820000 0x2f000 C:\WINDOWS\System32\IMM32.DLL
0x0000000004200000 0x18000 C:\WINDOWS\SYSTEM32\CRYPTSP.dll
0x0000000003930000 0x38000 C:\WINDOWS\system32\rsaenh.dll
0x0000000004220000 0xc000 C:\WINDOWS\SYSTEM32\CRYPTBASE.dll
0x0000000004eb0000 0x82000 C:\WINDOWS\System32\bcryptPrimitives.dll
0x00000000f8e30000 0x19000 C:\WINDOWS\SYSTEM32\SAMCLI.DLL
0x0000000003e00000 0xc000 C:\WINDOWS\SYSTEM32\NETUTILS.DLL
0x0000000003e10000 0x43000 C:\WINDOWS\SYSTEM32\LOGONCLI.DLL
0x00000000f8d10000 0xa000 C:\WINDOWS\SYSTEM32\VERSION.dll
Here is a list of DLLs provided by Quartus :
0x00000000a08f0000 0x1b000 C:\intelfpga_pro\23.4\quartus\bin64\quartus_py.exe
0x00000000fffc0000 0x6000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_main_globals.dll
0x00000000e76d0000 0x1fb000 C:\intelfpga_pro\23.4\quartus\bin64\tcmalloc_minimal.dll
0x00000000f45e0000 0x59000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_mem.dll
0x00000000e7550000 0x172000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_msg.dll
0x00000000cd8a0000 0x1b4000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_gen.dll
0x00000000ff420000 0x14000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_py.dll
0x00000000a8990000 0x42b000 C:\intelfpga_pro\23.4\quartus\bin64\python38.dll
0x00000000fbdf0000 0x1b000 C:\intelfpga_pro\23.4\quartus\bin64\VCRUNTIME140.dll
0x00000000e4750000 0x8e000 C:\intelfpga_pro\23.4\quartus\bin64\MSVCP140.dll
0x00000000ffd20000 0xc000 C:\intelfpga_pro\23.4\quartus\bin64\VCRUNTIME140_1.dll
0x00000000ff9d0000 0x6000 C:\intelfpga_pro\23.4\quartus\bin64\udm_barebones.dll
0x00000000f3400000 0x2e000 C:\intelfpga_pro\23.4\quartus\bin64\CCL_ERR.dll
0x00000000f2b30000 0x53000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_thr.dll
0x00000000c24b0000 0x1f3000 C:\intelfpga_pro\23.4\quartus\bin64\dbghelp.dll
0x00000000ff410000 0x7000 C:\intelfpga_pro\23.4\quartus\bin64\tbbamalloc.dll
0x00000000a5170000 0x323000 C:\intelfpga_pro\23.4\quartus\bin64\tbbmalloc.dll
0x00000000e74f0000 0x51000 C:\intelfpga_pro\23.4\quartus\bin64\tbb12.dll
0x00000000f2ca0000 0x2e000 C:\intelfpga_pro\23.4\quartus\bin64\boost_filesystem-mt-x64.dll
0x00000000e4710000 0x31000 C:\intelfpga_pro\23.4\quartus\bin64\VCOMP140.DLL
0x00000000e2400000 0x85000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_atcl.dll
0x00000000f2930000 0x26000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_big.dll
0x00000000ddb10000 0x3f000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_cfg_ini.dll
0x00000000cd840000 0x53000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_fio.dll
0x00000000f3b10000 0x14000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_ver.dll
0x00000000faad0000 0xb000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_osi.dll
0x00000000cd7e0000 0x59000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_qtl.dll
0x000000006ded0000 0x18a000 C:\intelfpga_pro\23.4\quartus\bin64\tcl86.dll
0x00000000f34f0000 0x19000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_tst.dll
0x00000000ee710000 0x24000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_fstr.dll
0x00000000c2c40000 0x136000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_sqlite3.dll
0x00000000f3320000 0x17000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_xml.dll
0x00000000cd600000 0x58000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_pdb.dll
0x00000000a4e80000 0x2e7000 C:\intelfpga_pro\23.4\quartus\bin64\xerces-c_3_2.dll
0x00000000e9d90000 0x2a000 C:\intelfpga_pro\23.4\quartus\bin64\fmt.dll
0x00000000f2c60000 0x1b000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_zlib.dll
0x00000000a4b20000 0x352000 C:\intelfpga_pro\23.4\quartus\bin64\libcrypto-1_1-x64.dll
0x00000000a4950000 0x1ce000 C:\intelfpga_pro\23.4\quartus\bin64\icuuc69.dll
0x00000000f2670000 0x1e000 C:\intelfpga_pro\23.4\quartus\bin64\ccl_clw.dll
0x00000000e3800000 0x22000 C:\intelfpga_pro\23.4\quartus\bin64\lz4.dll
0x00000000c13d0000 0xb4000 C:\intelfpga_pro\23.4\quartus\bin64\zstd.dll
0x00000000f25f0000 0x12000 C:\intelfpga_pro\23.4\quartus\bin64\LZMA18.dll
0x00000000d1090000 0x31000 C:\intelfpga_pro\23.4\quartus\bin64\liblzma.dll
0x00000000c3d70000 0x1b59000 C:\intelfpga_pro\23.4\quartus\bin64\icudt69.dll
0x00000000f4a00000 0xf000 C:\intelfpga_pro\23.4\quartus\bin64\python3.DLL
0x00000000f2270000 0x18000 c:\intelfpga_pro\23.4\quartus\bin64\python\lib\_bz2.pyd
0x00000000e1c80000 0x2b000 c:\intelfpga_pro\23.4\quartus\bin64\python\lib\_lzma.pyd
0x00000000f0c90000 0x17000 c:\intelfpga_pro\23.4\quartus\bin64\python\lib\_socket.pyd
0x00000000f42f0000 0xa000 c:\intelfpga_pro\23.4\quartus\bin64\python\lib\select.pyd
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @prashant_gohel,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I have tried to uninstall all version of python from my PC and re-install 3.8.10 but still facing the same application error randomly on system power cycle.
I have run the list DLL command as you have mentioned and attached the out.txt file here.
Recently, we have updated to Windows 11, so the list is based on the Windows 11.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
We have observed the similar issue while using quartus_pfg.exe as well, this is with the Quartus 25.1
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @prashant_gohel ,
I will be representing @DivyaG_Altera while she is temporary away.
Our team is concerned with the files' integrity in your system, and we wish to get more info on them.
Please hold on while our team is preparing script to run file integrity checks in your system.
Liang Yu
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The script for Windows 11 is ready, and attached in this article.
1. Update the required_files_win11.txt based on your system's Windows installation directory and Quartus installation directory paths.
2. Run generate_md5.bat (as shown below)
> generate_md5.bat required_files_win11.txt my_md5.txt
3. This will produce my_md5.txt
4. Run file compare
> fc required_files_win11_md5.txt my_md5.txt
5. This will report the lines that are different between the two files.
6. Please share your results with us.
Alternatively, you can also use Listdlls.exe (link).
1. Enter Nios V Shell
2. Run Listdlls.exe
> Listdlls.exe quartus_py > my_raw.txt
3. Run file compare
> fc required_files_win11_raw.txt my_raw.txt
Liang Yu
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Liang Yu,
Thank you for sharing the script files.
I have executed the script as suggested and copied the command prompt log(compare_25.1.txt) to share with you. The script was run on a Windows 11 PC with Quartus version 25.1.
Could you please share the required_files_win11_md5.txt file for Quartus Prime Pro 23.4 as well?
Thanks and regards,
Prashant Gohel
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for the compare_25.1.txt.
I shared the txt file to my colleagues for their analysis.
It seems that a file is missing in your system - WINDOWS\System32\umppc19811.dll , FILE NOT FOUND
Let's wait for their advice on the missing file.
I will keep you updated on any progress soon.
Also relayed your request to them on the Quartus Prime Pro 23.4 's required_files_win11_md5.txt too.
Liang Yu
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Attached the Quartus Prime Pro 23.4 's required_files_win11_md5.txt in the ZIP package.
About the missing umppc19811.dll,
- It might be possible that it have a different version number. Try the command below & see if it has a different version:
dir C:\Windows\system32\umppc*
- If the umppc*.dll is truly missing, try the DISM command (Deployment Image Servicing and Management tool). You might need to run Command Prompt with Run As Administrator.
To check the system health:
dism /online /Cleanup-Image /CheckHealth
If a problem is detected, perform the auto-fix.
dism /online /Cleanup-Image /RestoreHealth
Lastly, can you share your Windows 11 system info?
Run "systeminfo", report back the OS Name & OS Version.
For example, our system here is:
OS Name: Microsoft Windows 11 Enterprise
OS Version: 10.0.22631 N/A Build 22631
Liang Yu
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Liang Yu,
Here is the information about the Windows 11.
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.26100 N/A Build 26100
I have run the same for Quartus 23.4 and atached the command promt log here.
I have checked the dir C:\Windows\system32\umppc* command and didn't found any file.
Will try the DISM command and share the result with you.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I have run the DISM command, But still not found the umppc dll files.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
