After installing Nios II IDE 1.1 evaluation version, I cannot find the MicroC/OS-II. So, where can I install it?
Thanks, NeoLink Copied
The evaluation version of the kit doesn't contain uCOS-II.
This is because you need to buy a development licence in order to use it (the price of the licence is included in the full kit).- Mark as New
hi,
you need to buy a full version of nios II kit.- Mark as New
Hi All,
what is the license policy for uC/OS II included with NIOS2 dev kit? I mean, If I buy an NIOS II dev kit, is it free (i.e no royalties on all generated binaries) to use uC/OS II for commercial application ?- Mark as New
hi,
The MicroC/OS-II,they have provided with the Nios II kit is for educational purposes only,u cannot make a commertial product with it.To make ur own product,u have to obtain a license,MicroC is not an open source RTOS.If u want to make ur own product,it is better to use uClinux to develope ur application,since uClinux is open -source,freely available and can be ported to Nios II. bye manish- Mark as New
If you develop a commercial application with uC/OS-II, you need to obtain a license from Micrium. The license is NOT free. In fact, each different product that embeds uC/OS-II (assuming a single CPU) requires a different license.
uC/OS-II is included for FREE for development purposes ONLY. Jean J. Labrosse --- Quote Start --- originally posted by bigboss25@Jun 21 2006, 07:39 AM hi all,
what is the license policy for uc/os ii included with nios2 dev kit?
i mean, if i buy an nios ii dev kit, is it free (i.e no royalties on all generated binaries) to use uc/os ii for commercial application ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16314)
--- quote end ---
--- Quote End ---
--- Quote Start --- originally posted by micrium+jun 30 2006, 10:39 am--><div class='quotetop'>quote (micrium @ jun 30 2006, 10:39 am)</div>
--- quote start ---
if you develop a commercial application with uc/os-ii, you need to obtain a license from micrium. the license is not free. in fact, each different product that embeds uc/os-ii (assuming a single cpu) requires a different license.
uc/os-ii is included for free for development purposes only.
jean j. labrosse
<!--quotebegin-bigboss25@Jun 21 2006, 07:39 AM hi all,
--- quote end ---
--- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16577)</div> [/b] --- Quote End --- Thanx a lot. One more question. How much the uC/OSII for NIOS2 license costs? Regards.
