Hello all,
I was developing some new hardware and had problems debugging my own ISR. I got the code below from Slacker( modified slightly), and it helped me quickly zoom into my new hardware problem, spurious interrupt. I run the code and hardware through Modelsim 6.0c and it works fine. For a new piece of HW, just change base address and make your own interrupt source, mine is a fifo read that causes an underflow ( and an interrupt). I did see a problem with my component when I accidentally built my module with dynamic alignment instead of native. Of course I got incorrect reads( my peripheral is only 8 bits), but worse, my interrupt would be set and my isr would not work. Not sure why, but native alignment is correct for me anyway. Hope this is useful for someone. -Baycool ****************************************** /* Includes */ # include "io.h"# include "system.h"# include "sys/alt_irq.h"# include <stdio.h># include <stdlib.h># include "alt_types.h" const unsigned int CMD_AVALON_BASE = (unsigned int) 0x00100800; unsigned int check_fifo; /* Assumes existence of SOPC component*/ /* The ISR for the irqgen component. */ static void handle_irqgen_isr(void* context, alt_u32 id) { /* Extract the "count". */ int* count_ptr = (int*) context; /* Set the count variable. */ *count_ptr = 1; /* Clear the IRQ. */ IOWR(CMD_AVALON_BASE, 20, 1); } /* "Initializes" the irqgen component. * - Registers and ISR */ static void init_irqgen(int* count) { /* Register the ISR. */ alt_irq_register( 1, count, handle_irqgen_isr ); } /* The main loop. Capture Interrupt */ int main(void) { printf("Begin Cmd Avalon Test!\n"); /* A count variable which tracks if an interrupt has occured. */ int count = 0; /* Initialize the irqgen component. */ init_irqgen( &count ); /* Cause Interrupt */ check_fifo = IORD(CMD_AVALON_BASE,0x0); printf("Fifo is : 0x%X \n", check_fifo); /* main loop */ while( 1 ) { if( count == 1 ) { printf(" Got interrupt, You lucky dog !! \n"); count = 0; } } }Link Copied
