I am having problems with the flash card when ucLInux boots ... It first recognizes hda1 as iCREATIVE flash memory card, then when trying to "multmode_set" it returns a status error DriveReady seek complete error ... and then I can't mount it after boot .... Does anyone have a clue on this ? cya,melLink Copied
Hi mel
I had the same seek error on my card. Try formating your CF card through a pc. Full format with NO LABEL, and default left as is. Hope this helps... Rual
