12748 Discussions
GDB & GDB-SERVER for app debugging
Is there precompiled binary of GDB & GDB-SERVER available for debugging applications on linux? Please provide link if available.
Shakthi
what about debugging by using the Eclipse IDE? actually i never used this but according to the linux docs it should work.
I prefer to debug with printf.
Hi, try using this for debuging . Not great but better than having printfs everywhere .
* debug_segfault.c
* Handy little code for debugging embedded applications where too many
* printfs on console changes program behaviour. Mighty useful if no gdb
* or other debugger support.
*# define DEBUG_SEGFAULT, register signal(SIGSEGV,(void*) sig_segv_handle)
* in main and sprinkle code with macro DEBUG_SEGFAULT_POINT
* Copyright © 2006 by Vishal Oliyil Kunnil
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
* Original author:
* Vishal Oliyil Kunnil <vishal.ok@gmail.com
# include <stdio.h># include <unistd.h># include <string.h># include <signal.h>
/* Contents of below# ifdef to be globally visible */# ifdef DEBUG_SEGFAULT
char seg_file[10],seg_function[20];
int seg_line_number;
void sig_segv_handle(void) {
printf("caught SIGSEGV in\n");
printf("\tfile = %s\n", seg_file);
printf("\tfunction = %s\n", seg_function);
printf("\tapprox. line = %d\n", seg_line_number);
exit(0);
# define DEBUG_SEGFAULT_POINT
strcpy(seg_file, __FILE__);
strcpy(seg_function, __FUNCTION__);
seg_line_number = __LINE__; # else
# define DEBUG_SEGFAULT_POINT do { } while(0)# endif
int foo(void) {
return 0;
int bad_bad_function(void) {
char *null_pointer;
null_pointer=NULL;
//should segfault - de-referencing null pointer, do not try this @home!
printf("%c",*null_pointer);
return 0;
int main(void) {
int ret;
signal(SIGSEGV,(void*) sig_segv_handle);
# endif
foo();
printf("zzzzz...... sleeping ....\n");
sleep(1);
printf("call segfaulting function....\n");
ret=bad_bad_function();
if (!ret) printf("no segfault, exiting ok....\n");
return 0;
