GNU linker
Dear everybody,
I have noted a strange behaviour of the GNU linker whenever I have declared
a "const char" structure of less than 10 bytes size. Instead to allocate the structure
in the .text section, the linker has allocated the structure in the .data section. If
the structure is greater than 9 bytes size, the linker allocates its in the .text
section.
Could you explain this behaviour ?
Best Regards
/Alessandro
