12743 Discussions
GSFI AVL MEM for Cyclone 10GX 220
tato_pt
HEllo! I want to run a .elf file for Nios Vfrom flash on EPCQ1024L connected to a Cyclone 10GX 220 device.
The literature says to use:
elf2flash --input software/app/debug/yyyyyy.elf \
--output flash.srec --reset [reset offset + base address of GSFI AVL MEM] \
--base [base address of GSFI AVL MEM] \
--end [end address of GSFI AVL MEM]
but I cannot understand what the base and end addresses for GSFI AVL MEM should be. How can I find this out?
Thanks!
- Paulo
JingyangTeh_Altera
Hi
The Base and End Address of the GSFI could be found under the Address Map view in Platform Designer.
With the screenshot above the start and end address will be 0x0 to 0x1f_ffff
Jingyang, Teh
JingyangTeh_Altera
Hi
Do you have any update on this case?
Did you managed to generate the hex file for the GSFI?
Jingyang, Teh
JingyangTeh_Altera
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
