Generate problem
Hello everyone:
I encountered a strange problem during the SOPC Builder generate process.
I added a component "DM9000A"(Provided in DE2's kit) to the component library and then added one instance to my system. But SOPC Builder(Quartus 5.0 SP2) can't generate it, while the SOPC Builder of quartus 6.0 can generate it succesfully(That's why I call it strange,But I have do my project with 5.0..).
Dose anybody know why?Looking forward to your reply,Thanks!
Below is the error information:
*************************************************************************# 2007.03.22 10:38:41 (*) Running Generator Program for dm9000a_0
ERROR:
In object '' of class e_port: can't access `vhdl_record_type' field
known fields are:
_AUTOLOAD_ACCEPT_ALL
__is_inout
_creation_history
_direction
_export
_negated
_never_export
_object_list
_parent_set
_project_set
_ptf_written
_signal_list
comment
copied
declare_one_bit_as_std_logic_vector
default_value
depth
indent
isa_dummy
name
paragraph
trimmed
type
vhdl_declare_only_type
vhdl_default
width
known pointers are:
_parent
_project
keys:
_permitted
_pointers
by the way, this object is a dummy
Error: Generator program
for module 'dm9000a_0' did NOT run successfully.
