nios assembly in C code
hi everyone,
This is my first participation to the forum. I'd appreciate your help.
I'm trying to convert a function in C code into assembly to reduce the time taken for execution and compilation. i just wanna know how to mix between the c code and the nios assembly.is there a certain syntax to use?
and how to access the C variables in the assembly code. for example:
void filter (int input,int & y)
how to access the variable "input" using assembly?i mean how to know the address that this variable is saved at, or whatever?
thx a lot.looking forward to ur reply
Read the other posts!!!! stop flooding for the same question!
Hi Mado,
Welcome to the forum from me too.
Banx.
