Socket Program.
Hi,everybody
I have build a socket program,it has server and client program.
I will run server on De2 board and client on PC.
But I have problem.
Client is excute on "colinux" or "NiosII SDK shell"?
How to compile client program and run on PC?
I don't know "compile" and "excute" command on colinux?
Need your help!
NiosQ
You can use gcc to compile your client program, and run it within coLinux shell. But coLinuxs needs a virtual network adaptor driver to access network interface (or bridge) from Windows. You may read the wiki of coLinux or Blackfin.
I would suggest you install a native Linux on one partition of your PC, eg CentOS 4.4. It would be easier than coLinux for a newbie.
--- Quote Start ---
originally posted by hippo@Mar 21 2007, 10:14 AM
you can use gcc to compile your client program, and run it within colinux shell. but colinuxs needs a virtual network adaptor driver to access network interface (or bridge) from windows. you may read the wiki of colinux or blackfin.
i would suggest you install a native linux on one partition of your pc, eg centos 4.4. it would be easier than colinux for a newbie.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22395)
--- quote end ---
--- Quote End ---
Hi,hippo
Your are Nios God!
great!
thank for your response.
I&#39;m a Nios newbie. If i use centOS ,then how to setup network?
I use centOS just compile client program and run it.
Can you teach me how to compile client program and run it on CentOS?
thank your very much!
NiosQ
You may read the Redhat&#39;s step by step guide,
http://www.redhat.com/docs/manuals/enterprise/ (http://www.redhat.com/docs/manuals/enterprise/
You may also check other redhat docs, and CentOS wiki .
Programming on Linux PC is jus the same as Nios2 ucLinux.
gcc hello.c -o hello
./hello # to run the compiled hello
