12748 Discussions
Generating Hierarchical Systems in Qsys
hi
I implement a top level system, which is a multiprocessor system, with Qsys then generate the top level system for making subsystem's .SOPC file, but it does not make that.
I am so confused, how can i do this(making subsystem's .SOPC files)?
If you are creating the system in Qsys, you won't find SOPC files. The subsystem components will be Qsys files. If you have a Qsys system in your active Quartus project and you open Qsys, it should appear at the top of the Component Library window under Project-System.
hi
I did every thing in the right flow as you mentioned.
I design a hierarchical system in Qsys. In our design we have a "Top Level System" contains 3 subsystems, which each have one processor NiosII, JTAG, and "avalon memory map pipeline bridge". Cod memory of this processors define as "absolute" type, which is maped to a memory in the Top level system by "avalon memory map pipeline bridge ".
But I still have problems as below:
If we create a .sopcinfo file for a subsystem, and attempt to build a BSP based on that .sopcinfo file, when the BSP or application tries to refer to components in the top level, those references fail.
I found this solution for my problem:
"you must generate a .sopcinfo from
the top-level system, and base the BSP on this .sopcinfo file."
Unfortunately, I have only the .sopcinfo file of top-level system.(that means I do not have .sopcinfo file of subsystems!!!).
Please help me in this problem.
Thanks a lot.
Are you trying to create a bsp based on the subsystem sopcinfo files? I think you just need the bsp for the top level and make sure you have access to all the sopcinfo files.
how could i run niosII application on the processors of subsystem in a situation that the sopcinfo file of this subsystem doesnt exist?
I don't have a hierarchical project to look at but I would guess that when you create the project in the SBT, you choose the sopcinfo file for the top level and then the processor you'd like to link to the project. That way you can target different processors in the same design.
Excuse me
how i can link the processor to the project ?
When you create a new application and BSP template, you get a screen like the one attached. After you target the sopcinfo file, it gives a list of processors. I only have one but I expect you'll see them all.
Wooooooooooow!I get successful!
Thank you very much. Thanks for your aid.
All of the CPUs should be showing up assuming you are generating the top level system which contains the CPUs below it or within it.
There seems to be some confusion about what you need to generate. Think of this like verilog or VHDL, you compile a top level module and all the children are compiled too. The same goes for Qsys, if you generate the top level system then all of the children (and their children, and so on....) are generated as well.
