12747 Discussions
Get stdout from Nios (JTAG) to custom application on a PC
GK4
Débutant
1 095 Visites
I am trying to read stdouts from my Nios from JTAG-UART with the JTAG UART Intel FPGA IP in the system console (is this the right place?).
That's because I want to be able to read the output and analyse it with my own software (stdin and out from the console to my application).
With the GDB debugger I am able to read and write, but I need to be able to hot swap the pc where the application is running.
I read some forum entries:
https://forums.intel.com/s/feed/0D50P00003yyTk4SAE
https://forums.intel.com/s/feed/0D50P000045gccwSAA
But I wasn't able to create a "listener".
I tried to fiddle manually with the GDB server:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed51004.pdf
But I wasn't able to find the correct commands/configuration to read the stdout from the slave.
Any help would be appreciated.
0 Compliments
3 Réponses
FawazJ_Altera
Employé
876 Visites
We dont have such solution.
You can only change stdin/stdout if you have a real UART port in your board. In this case, you can port stdin/stdout to that UART, and this UART is connected to PC where you can run your custom application and read the data.
0 Compliments
GK4
Débutant
876 Visites
Thank you for the information.
Is this planned? Or do we have to expect that there will never be a some sort of API to communicate with custom software over JTAG/UART?
I mean there was something like the jtag-atlantic DLL.
0 Compliments
FawazJ_Altera
Employé
876 Visites
hello,
I have checked with our internal team, there is no current plan for that.
0 Compliments
Répondre
