Help! Problem in linking!
I met the problem whem linking:
Unable to reach (at 0x0009bf4c) from the global pointer (at 0x000861e0) because the offset (89452) is out of the allowed range, -32678 to 32767.
The code was more than 64KB。 How to solve it?
A document said that the -G compiler option should be fixed. This option sets the
threshold size. But how to make it?
Help me. Thanks!
hi Dugufei,
did you try -G0 ?
i had this problem with redboot... fixed with this option. found somewhere here in this forum. maybe it works for you, too.
regards, martin
Yes, I've tried from -G0 to -G4. But it didn't work!
The Altera's document didn't say clearly.
--- Quote Start ---
originally posted by mrwgm@Oct 26 2006, 04:24 AM
hi dugufei,
did you try -g0 ?
regards, martin
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18925)
--- quote end ---
--- Quote End ---
you should double check your code, something should be wrong with your source.
you can try get rid of the variable which lead to fail.
Hi Dugufei,
I sometimes get this error when trying to access data in a different section. I have a section of battery-backed SRAM, away from the RAM used for my code and bss. To put something in the NVR I have to use:
# define COMM_NVR __attribute__((section(".common_nvr")))
// example of putting variable in NVR.
unsigned char fred COMMON_NVR;
When I want to access fred from another file I have to:
extern unsigned char fred COMMON_NVR;
If I forget to add the COMMON_NVR attribute then I get the linker error you describe, &#39;Can&#39;t reach....&#39;.
So maybe your unreachable variable isn&#39;t where you think it is.
Banx.
But I can run seccussfly the same code in ARM7 platform. So, I think the code is all right.
Now I want to port the code into Nios2.
The problem is what is the right -G compiler option&#12290;
