12748 ディスカッション
Help! Problem in linking!
名誉コントリビューター II
1,349件の閲覧回数
I met the problem whem linking:
Unable to reach (at 0x0009bf4c) from the global pointer (at 0x000861e0) because the offset (89452) is out of the allowed range, -32678 to 32767.
The code was more than 64KB。 How to solve it?
A document said that the -G compiler option should be fixed. This option sets the
threshold size. But how to make it?
Help me. Thanks!
0 件の賞賛
5 返答(返信)
名誉コントリビューター II
604件の閲覧回数
hi Dugufei,
did you try -G0 ?
i had this problem with redboot... fixed with this option. found somewhere here in this forum. maybe it works for you, too.
regards, martin
名誉コントリビューター II
604件の閲覧回数
Yes, I've tried from -G0 to -G4. But it didn't work!
The Altera's document didn't say clearly.
--- Quote Start ---
originally posted by mrwgm@Oct 26 2006, 04:24 AM
hi dugufei,
did you try -g0 ?
regards, martin
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18925)
--- quote end ---
--- Quote End ---
名誉コントリビューター II
604件の閲覧回数
you should double check your code, something should be wrong with your source.
you can try get rid of the variable which lead to fail.
名誉コントリビューター II
604件の閲覧回数
Hi Dugufei,
I sometimes get this error when trying to access data in a different section. I have a section of battery-backed SRAM, away from the RAM used for my code and bss. To put something in the NVR I have to use:
# define COMM_NVR __attribute__((section(".common_nvr")))
// example of putting variable in NVR.
unsigned char fred COMMON_NVR;
When I want to access fred from another file I have to:
extern unsigned char fred COMMON_NVR;
If I forget to add the COMMON_NVR attribute then I get the linker error you describe, &#39;Can&#39;t reach....&#39;.
So maybe your unreachable variable isn&#39;t where you think it is.
Banx.
名誉コントリビューター II
604件の閲覧回数
But I can run seccussfly the same code in ARM7 platform. So, I think the code is all right.
Now I want to port the code into Nios2.
The problem is what is the right -G compiler option&#12290;
返信
