- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi!
I'm having a problem with creating a project in Nioss II eclipse. When I go to file/new--> Nios II application and BSP template, I have to find the SOPC information file. I have no problem locating this file but when i press finish I get this error-message: Failed to execute: ./create-this-bsp --cpu-name cpu --no-make. I'm using windows 8.1 (unfortunately) och I've tried to run Nios as an administrator. I'll upload two screenshots and hopefully somebody could help me with this.Link kopiert
3 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Avoid non-English (ä, å...) characters (and spaces) in the path :-)
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
--- Quote Start --- Avoid non-English (ä, å...) characters (and spaces) in the path :-) --- Quote End --- Thank you, it works better now:) But I still have a problem. Whenever I try to run the program as "Nios II hardware" I get an error message that says "downloading elf process failed nios ii". Do you know why?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You need a board to "run as hardware" : an Altera Dev kit board or your custom board.
You need to match your software with your hardware. More precisely, you need to match your BSP (software) with your QSYS/SOPC which should be in your FPGA on your board. A fail download is often caused by a watchdog, a reset, Mismatching Qsys/SOPC (see "sysid").
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
