12745 Discussions
Help with state machines in eclipse (NIOS II)
How can i initalise the states and cause this state machine of 3 states to work effectively.
My code if found below:
# include <stdio.h># include <io.h># include <system.h># include <alt_types.h># include "altera_avalon_pio_regs.h"
int main()
alt_u32 key_in, signal_raknarvarde, state;
# define Scan_keys_state 0x01
# define write_to_leds_state 0x02
# define no_keys_state 0x03
// Initiering av variabler och utsignaler till hårdvaran
//int state = Scan_keys_state;
//int state = write_to_leds_state;
//int state = no_keys_state;
// loop for ever
while(1)
switch (state) {
case Scan_keys_state:
// if key_in, state = write_to_leds;
break;
case write_to_leds_state:
break;
case no_keys_state:
// Kolla att ingen knapp är nertryckt,
//denna function kan göra att //wait(time); inte behövs
break;
return 0;
Thanks for the help in advance
You'll have to define a bit better "work effectively". A problem I see in your code though is that you don't give an initial value to the state variable. You should uncomment one of the three lines that do that.
