12748 Discussions
How to boot from SPI Flash?
I have design with spi flash to store my firmware and sdram to run it from.
My EPCS is too small to run code from it.
Can anyone give me boot-loader code to boot my system from SPI Flash?
My SPI flash is ST M25Pxx.
If I understand well, the boot-loader can integrate to the NIOS within the hardware image. Is that correct?
Hi motal,
You really shouldn't need much code to load a small application (a 2nd stage
boot loader) that pulls your code in from an SPI device. How much room
is left on your EPCS?
Yes -- or you could try to replace/modify the default bootloader in the EPCS
peripheral -- have it load from your SPI device rather than the EPCS device.
From a practical point-of-view, the EPCS is just an SPI device that you
don't get to do pin assignments for ;-)
--Scott
--- Quote Start ---
originally posted by smcnutt@Jan 25 2007, 06:48 PM
how much room is left on your epcs?
--- Quote End ---
After compression of my hardware image it's allways fit exactly to my EPCS1 - 128KB = 1MBit.
So I can't put any software (even a little boot-loader) on the EPCS.
I could write the low-level code to access the SPI Flash myself, but I'll be glad to get ready code, if someone already write that.
2nd option. I saw SPI Flash core in OpenCores.com - it is possible to tell the SOPC Builder to reset from SPI memory with this core? - normally the SOPC Builder doesn't recognize SPI interfaced as memory.
How can I add this core to SOPC builder?
Hi motal,
Logic, code, whatever ... if you have no room left on your configuration device you're in an
unfortunate position. Perhaps you should use a bigger configuration device. ;-)
In any regard, I don't think I was very clear in my last post:
> or you could try to replace/modify the default bootloader in the EPCS peripheral.
The EPCS controller uses on-chip memory that contains a small bootloader. If you are _already_
using the EPCS controller, you can try to replace the existing bootloader. Provided your
(bootloader) implementation is smaller than the default, it should fit in your EPCS.
--Scott
