How to debug in ASM code
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Hi,
I&#39;m trying to debug assembler code, but the debugger never jumps into the asm code like it does with c code.
It just ignores the breakpoint set on the asm line.
How do I write asm code to "convince" the compiler/assembler to add debug code?
--- Quote Start ---
originally posted by david_cai@Dec 14 2005, 02:12 AM
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif hi,
i&#39;m trying to debug assembler code, but the debugger never jumps into the asm code like it does with c code.
it just ignores the breakpoint set on the asm line.
how do i write asm code to "convince" the compiler/assembler to add debug code?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11528)
--- quote end ---
--- Quote End ---
When in the debugger, select the disassembly mode (icon). Then when calling your assembler routine, you can "step into" the that code.
hi, everybody
I can step into asm rountine.
But how can I run into asm rountine?
I set a breakpoint in asm code, then run the program, but it can&#39;t stop at the breakpoint.
Anyone help?
hello :
i am new !
i don&#39;t know how to set a breakpoint,anyone can help me?
Hi wbqyy,
You can set a breakpoint at the line by double click at the left edge space of them.
hi, everybody
Anyone help?
