c programming for Pin pio
Hi there...i'm currently having problem of understanding the pin input pio....
my nios is connected to the 16 bits pio pin in the development board...how to write a c code to retrieve the inputs from this pio..
since this inputs are in binary, do i need to convert to decimal or the system itself will convert for me in C language.
thnaks and regards
wayne
--- Quote Start ---
originally posted by niceguylow@Dec 7 2005, 02:56 PM
hi there...i'm currently having problem of understanding the pin input pio....
since this inputs are in binary, do i need to convert to decimal or the system itself will convert for me in c language.
thnaks and regards
wayne
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11393)
--- quote end ---
--- Quote End ---
You can try using the PIO functions made available by Altera... like the one used in the count_binary example of the HAL...
The numbers you&#39;ll read from the PIO have to be interpreted as a set of bits inside a 32-bit integer... For example, if you have a 2 bit PIO, you&#39;ll end up having the 2 bits valies inside the 2 less significant bits of the integer you read from the peripheral.
bye
Paolo
--- Quote Start ---
originally posted by paolo.gai+dec 7 2005, 08:38 am--><div class='quotetop'>quote (paolo.gai @ dec 7 2005, 08:38 am)</div>
--- quote start ---
<!--quotebegin-niceguylow@Dec 7 2005, 02:56 PM
hi there...i&#39;m currently having problem of understanding the pin input pio....
thnaks and regards
wayne
--- quote end ---
--- Quote End ---
bye
Paolo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11396)</div>
[/b]
--- Quote End ---
this is my sample of the c ....will it work ?
let say my pio is a 16 bit input...would it put receive the 16 bits input.
since np_pio is defined as int...the 16 bits are automatically converted into integer?
np_pio *pio = na_pio;
if i want to access obtain the data...
pio->np_piodata;
Are you using IORD_ALTERA_AVALON_PIO_DATA(base) ?
Paolo
Hello niceguylow,
the PIO Core is described in the Quartus II Development Software Handbook Volume 5: Embedded Peripherals (http://www.altera.com/literature/quartus2/lit-qts-peripherals.jsp). For accesing the PIO registers there are some macros which are included in “altera_avalon_pio_regs.h”:
#define IOADDR_ALTERA_AVALON_PIO_DATA(base)           __IO_CALC_ADDRESS_NATIVE(base, 0)# define IORD_ALTERA_AVALON_PIO_DATA(base)             IORD(base, 0) # define IOWR_ALTERA_AVALON_PIO_DATA(base, data)       IOWR(base, 0, data) # define IOADDR_ALTERA_AVALON_PIO_DIRECTION(base)      __IO_CALC_ADDRESS_NATIVE(base, 1)# define IORD_ALTERA_AVALON_PIO_DIRECTION(base)        IORD(base, 1) # define IOWR_ALTERA_AVALON_PIO_DIRECTION(base, data)  IOWR(base, 1, data) # define IOADDR_ALTERA_AVALON_PIO_IRQ_MASK(base)       __IO_CALC_ADDRESS_NATIVE(base, 2)# define IORD_ALTERA_AVALON_PIO_IRQ_MASK(base)         IORD(base, 2) # define IOWR_ALTERA_AVALON_PIO_IRQ_MASK(base, data)   IOWR(base, 2, data) # define IOADDR_ALTERA_AVALON_PIO_EDGE_CAP(base)       __IO_CALC_ADDRESS_NATIVE(base, 3)# define IORD_ALTERA_AVALON_PIO_EDGE_CAP(base)         IORD(base, 3) # define IOWR_ALTERA_AVALON_PIO_EDGE_CAP(base, data)   IOWR(base, 3, data)
niosIIuser
alt_16 my_data;
my_data = IORD(YOUR_PIO_BASE_ADDRESS,0);
