12745 Discussions
How to generate vmlinux with debug symbols.
Hi All,
I want to use the debugger.
Therefore, I'm want to generate a vmlinux with debug symbols.
Have the following settings in Menuconfig.
Linux Kernel v2.6.30 Configration Kernel hacking ---> kernel debugging Compile the kernel with debug info
I think that the following changes.
But, vmlinux with debug symbols is not generated.
top\linux-2.6\Makefile ifdef CONFIG_DEBUG_INFO KBUILD_CFLAGS += -g KBUILD_AFLAGS += -gdwarf-2 endif
Vmlinux with debug symbols will be generated What should I do?
thanks a lot,
Hi All,
Worked by "make mrproper" and "make clean".
The following is a reference.
Linux Kernel v2.6.30 Configration Kernel hacking ---> kernel debugging Compile the kernel with debug info uClinux Distribution v4.0 Configration Debug Build ---> build debugable libraries build debugable applications Thanks to all.
