12747 Discussions
How to implement TCP/IP Client basing on NiosII? ---SSS works
Hello, does somebody know how to implement TCP/IP Client basing on NiosII?
I have DE2-115 Kit, and it works with simple socket server as a server(of course:p)
Thanks in advance!!!
I never tried it with Nios, but I guess you can do it like on other common systems.
First of all replace the bind() and listen() calls with connect(); then replace recv() with send() and change the code flow according to the client perspective.
I think you can use the select() as well to callback the event handler functions
