12748 Discussions
How to make sure nios send a single cycle control signal to peripheral?
hye everyone..this is a very basic question
i was testing how to control custom HW using nios. The custom HW in my case is just a simple counter
ive attach my counter to avalon bus and manage to give signal and read output from it. however a single control signal from nios triggered a few counts on my counter.
e.g :
if i do this in c
printf("count=%d",IORD_8DIRECT(COUNTER_0_BASE,1)); IOWR_8DIRECT(COUNTER_0_BASE,0,1); printf("count=%d",IORD_8DIRECT(COUNTER_0_BASE,1)); the output is:
0 3but i actually want it to count up a single value each time the nios tell it to.
this is my current interface for counter<->avalonbus:
module avalon_counter( //avalon signal clk, reset_n, read, write, readdata, writedata, address, chipselect, //conduit outCNT ); input clk, read, write, chipselect, reset_n; input address; input writedata; output reg readdata; //component signal reg cnt_up; reg cnt_dwn; wire oCNT; //conduit signal output outCNT; assign outCNT = oCNT; always@(posedge clk) begin if(!reset_n) readdata <= 8'b0; else begin if (chipselect == 1'b1) begin case(address) 1'b0: begin if(writedata) begin cnt_up<=1'b1; cnt_dwn<=1'b0; end else begin cnt_up<=1'b0; cnt_dwn<=1'b1; end end 1'b1: readdata<={2'b00,oCNT}; endcase end else begin cnt_up <= 1'b0; cnt_dwn<= 1'b0; end end end counter u1( .clk(clk), .resetn(reset_n), .cnt_up(cnt_up), .cnt_dwn(cnt_dwn), .oCNT(oCNT) ); endmodulei suspect that avalon only deassert chipselect after few cycle.so as long as the chipselect==1 cnt_up or cnt_dwn is always assert with value=1.
How can i make sure that a single command from nios only trigger a single count on my counter?
First, you are not testing if the CPU is reading or writing your component. While this doesn't have any impact in your case as you are using two different addresses it is best to only perform a write operation when the CPU actually intends to write. Usually when I design an avalon slave, I prefer to use the read and write control signals instead of chipselect and write_n.
Second, in some cases, when accessing a 8-bit bus, the NIOS CPU performs 4 accesses to get a 32-bit value. I don't remember in which cases it does it, but now I don't bother anymore and always use 32-bit data busses even if I just have 8-bit values to exchange.
I notice that read/write operation does not use a single clk cycle from the output and ive also read it in avalon bus specification. but im still quite confuse how with a IOWR operation i can make sure that only a single pulse of CNT_UP signal will be catch by my customHW(counter). should i like check an edge of the signal from avalon bus inside my avalon_counter interface?
--- Quote Start ---
--- Quote End ---
but isnt IORD_8DIRECT macro specificly means we accessing 8bit. or it still access 32 bit but masked the 8bit LSB?
You specify yourself the number of wait cycles when you create the component in SOPC builder. With the default values, a read signal is active during two cycles and a write signal during one cycle, so your code should be fine and you don't need to detect an edge on the avalon control signals.
For your second question, I don't know. I stopped trying to understand how the CPU does the 8-bit accesses and just do everything with 32-bit data busses. It saves a lot of trouble ;)
I think that the CPU is trying to do an 8-bit access but the switching fabric divides it in 4 8-bit accesses, but I'm not sure.
