Long integer library for C2H
I have a little trouble to find a good long integer library
that work with C2H. Some libraries use floating point
arithmetic (e.g., numerical recipes, slow on NIOS) or other (e.g. LIP) do
not compile at all with C2H. I would like to speed-up the RSA
algorithm but could not find a good working long integer
library so far.:confused:
Thanks -- I downloaded the package and the Mentor package seemed in C++, so it is not really supported by C2H, or could you used it with C2H? C2H acceleration I have seen were always using plain C not C++.
