In previous NIOS IDE, the debugger allowed to "Attach to existing program on target (no download)".
This was quite useful to inspect the state of a running program. How is it possible to do the same with the NIOS EDS 9.1sp2 ? Thanks, P9Link Copied
On older versions (<9.0sp1), I use StartMenu>Altera>...>Nios II Shell then, I type nios2-terminal type nios2-terminal --help for command line options (cable...) It should work on Nios II 9.1.- Mark as New
I also have this problem. I would like to do the debugging from the EDS, not from the command line. Best Regards Anne
