12745 Discussions
nios2-elf-objcopy: command not found
who can help me with the problem below:
[root@localhost uClinux-dist]# nios2-download -g ../3c120_default/linux.initramfs.gz
/opt/altera9.1/nios2eds/bin/nios2-download: line 586: nios2-elf-objcopy: command not found
how can i solve this problem~~ thanks!
you can use the "locate " to find the command ,and add the path to the env PATH. wish this may help
You have to find where the nios2-elf-objcopy lives. and add that directory to path (for bash : 'export PATH=$PATH:/absolute/path/to/directory' )
For my system its in
$nios2edsrootdir$/bin/nios2-gnutools/H-i686-pc-linux-gnu/bin/nios2-elf-objcopy
