12745 Discussions
RTP(Real-timeTransportProtocol) in linux on fpga
I want plant RTP on FPGA based on linux.
On PC, we use command
" g++ -o example1 example1.cpp -I /usr/local/include/jrtplib/ -ljrtp"
to compile a file.
but in FPGA linux we used toolchian nios2-linux-gnu-g++,so i use
"nios2-linux-gnu-g++ -o example1 example1.cpp -I /usr/local/include/jrtplib/ -ljrtp"
but it says
/usr/work/nios2-linux/toolchain-mmu/x86-linux2/bin/../lib/gcc/nios2-linux-gnu/4.1.2/../../../../nios2-linux-gnu/bin/ld: skipping incompatible /usr/work/nios2-linux/toolchain-mmu/x86-linux2/bin/../lib/gcc/nios2-linux-gnu/4.1.2/libjrtp.so when searching for -ljrtp
/usr/work/nios2-linux/toolchain-mmu/x86-linux2/bin/../lib/gcc/nios2-linux-gnu/4.1.2/../../../../nios2-linux-gnu/bin/ld: skipping incompatible /usr/work/nios2-linux/toolchain-mmu/x86-linux2/bin/../lib/gcc/nios2-linux-gnu/4.1.2/libjrtp.a when searching for -ljrtp
/usr/work/nios2-linux/toolchain-mmu/x86-linux2/bin/../lib/gcc/nios2-linux-gnu/4.1.2/../../../../nios2-linux-gnu/bin/ld: cannot find -ljrtp
I think it must be because the library is built based on gxx,not nios2-linux-gnu-gXX ,how can i get a proper lib
thanks
wangweike
