12748 Discussions
How to read Register Field (RegField) of adsp in DS-5?
Hi everyone,
I am trying to read/write register field designed in adsp using bare-metal projects in DS-5.
In adsp, I configure the address for two register fields (e.g a = 1 and b = 2, data width = 32, address width = 16).
In Qsys, I connect bus of this component (containing two reg fields) to h2f_lw_axi_master bus, the base address of its is 0x0004_0000.
Then, in DS-5 I use alt_write_word() and alt_read_word() functions to write/read data to these register fields as following.# define ALT_LWFPGASLVS_OFST 0xff200000# define REGFIELD_BASE 0x0004000# define REG1_BASE 0x0001# define REG2_BASE 0x0002
The read/write data is
read_data = alt_read_word(ALT_LWFPGASLVS_OFST+ REGFIELD_BASE+REG1_BASE);
and
alt_write_word(ALT_LWFPGASLVS_OFST+ REGFIELD_BASE+REG1_BASE, 0x08);
I put these functions after alt_bridge_init (ALT_BRIDGE_LWH2F) runs successfully, but it is not working.
Is there anything wrong in my program? Please help me to solve it.
Thank you so much.
Thuc
