12745 Discussions
How to resolve the error 'modelsim (vsim) is not on the path'?
ZikunTan
Hi!
I am initializing Intel HLS compiler according to the instruction. I have downloaded Quartus, Visual Studio and Modelsim.
What I typed 'C:\intelFPGA\18.1\hls\init_hls' in command prompt and press 'Enter', it says that 'Modelsim (vsim) is not on the path'. What's wrong with it? How can I resolve this error to initialize HLS compiler?
The error screenshot is shown below.
MuhammadAr_U_Intel
Vsim is looking for Modelsim executable path.
Make sure you have any version of Modelsim installed in your system and the executable path is added to windows environment variable "PATH"
Once Modelsim executable path is added, close, re-open command prompt and try executing the .bat script again to initialize.
thanks,
Arslan
Abe
Valued Contributor II
Capture.JPGClick the Start button and type Control, in the list of search items , select Control Panel and then System and Security. Then select View amount of RAM and Processor Speed under System . Next click the Advanced System Settings option in the left pane.
In the window that opens, click the Environment Variables option and select the Path option to highlight it. Now, click the Edit... button.
In the window that opens up, make sure to enter the Quartus and ModelSim installation path as shown in the screenshot. Then click Ok to close the windows, and then finally open the Command Prompt and try again.
ZikunTan
Yes, this problem was caused by my wrong environment setting of ModelSim. I have corrected my path and now it is going well. Thanks for your response.
xiaoshe
retry run visual_studio_2010 setup.exe and select repair
