How to start with?
Need to port uCLinux on Nios II. Please guide (mail, suggest doc/books/tutorials)
on how to start with?
You could download the microtronix distribution and read the read-me files included there. They have a simple step-by-step tutorial which will have you running uCLinux in less then an hour!
--- Quote Start ---
originally posted by wgoossens@Oct 19 2005, 12:19 PM
you could download the microtronix distribution and read the read-me files included there. they have a simple step-by-step tutorial which will have you running uclinux in less then an hour!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10442)
--- quote end ---
--- Quote End ---
thanks for the reply,
Got thr microtronics distribution
I am following the Linux Quick Start Guide
Creating Linux Kernel Project
In IDE while creating new project (say) kernel_first
after selecting proper ptf (I have tried with 1C20 and 1S40)
when I click on Finish in New Project Wizard
it gives error:
Project cannot be created
Reason:
Resource /kernel_first/build/arch/nios2nommu does not exist
How to resolve this?Whats the reason for this error?
Thanks and Regards
It looks like you haven&#39;t installed the uClinux plugin correctly.
Note that installing the plugin in a directory with a space in its name (e.g. c:\program files\ucLinux) doesn&#39;t generate errors while installing, but does when you&#39;re trying to use it...
--- Quote Start ---
originally posted by wgoossens@Oct 19 2005, 04:53 PM
it looks like you haven&#39;t installed the uclinux plugin correctly.
note that installing the plugin in a directory with a space in its name (e.g. c:\program files\uclinux) doesn&#39;t generate errors while installing, but does when you&#39;re trying to use it...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10452)
--- quote end ---
--- Quote End ---
I have reinstalled...
This time taking care there are no spaces in the names of folders
still I am getting same error
Looks like version issue:
I am trying with Nios II Destribution 1.4 which supports Nios II 5.0 IDE
Rahul
