12748 Discussions
How to use Strstix network
hi~~
Please ask!
i want use the network to spread the number to mp computer
server~~~Strstix
pc~~~~~Borland c++
so~How to start?
Where to have materials and can be consulted?
Thank!!^_^
Hi superstyle1,
I tried to start the same way like you. Here's what to do:
download lwip1.0.0 from the download section and try get the webserver design exmple up and running.
Then download the following document:
www.sics.se/~adam/lwip/doc/lwip.pdf
try to understand the working of the lwIP stack. Then use UDP or TCP, whatever you like the most
Good luck.
Danny
--- Quote Start ---
originally posted by dannyjacobs@Dec 5 2005, 08:10 AM
hi superstyle1,
i tried to start the same way like you. here's what to do:
then download the following document:
try to understand the working of the lwip stack. then use udp or tcp, whatever you like the most
good luck.
danny
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11324)
--- quote end ---
--- Quote End ---
Of course this will only work when you use the NIOS II IDE, but it gives you a good example of how it works...
Cheers,
Danny
Thank you!!
I go to try!!
--- Quote Start ---
originally posted by dannyjacobs@Dec 5 2005, 09:10 AM
hi superstyle1,
i tried to start the same way like you. here&#39;s what to do:
good luck.
danny
--- quote end ---
--- Quote End ---
hello!!
I can&#39;n find download lwip1.0.0 from
Can you send to me mail?
mail:49122041@webmail.stut.edu.tw
