hi~~
Please ask! i want use the network to spread the number to mp computer server~~~Strstix pc~~~~~Borland c++ so~How to start? Where to have materials and can be consulted? Thank!!^_^Link Copied
Hi superstyle1,
I tried to start the same way like you. Here's what to do: download lwip1.0.0 from the download section and try get the webserver design exmple up and running. Then download the following document: www.sics.se/~adam/lwip/doc/lwip.pdf try to understand the working of the lwIP stack. Then use UDP or TCP, whatever you like the most Good luck. Danny- Mark as New
--- Quote Start --- originally posted by dannyjacobs@Dec 5 2005, 08:10 AM hi superstyle1,
i tried to start the same way like you. here's what to do:
then download the following document:
try to understand the working of the lwip stack. then use udp or tcp, whatever you like the most
good luck.
danny
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11324)
--- quote end ---
--- Quote End --- Of course this will only work when you use the NIOS II IDE, but it gives you a good example of how it works... Cheers, Danny
Thank you!!
I go to try!!- Mark as New
--- Quote Start --- originally posted by dannyjacobs@Dec 5 2005, 09:10 AM hi superstyle1,
good luck.
danny
--- quote end ---
--- Quote End --- hello!! I can'n find download lwip1.0.0 from Can you send to me mail? mail:49122041@webmail.stut.edu.tw
